The offset is the depth of the hub on the rim. IX offset is ET41. and IX rim will fit other e30s but you'll need to get spacers to bring the wheel further out towards the fender because the offset will cause the wheel to rub the inner fender or parts of the suspension. Likewise you can put a regular e30 wheel on an IX. because the IX set up has already compensated for the depth of the hub. So a regular wheel will stick out a bit more on an IX since the offset is say 25 or 33. Which means the hub is shallower on non IX rims.
OK, so I know non-iX E30 rims fit on the iX without rubbing, but are there any potential problems that might disturb the AWD system or any driving or steering/handling issues by using 14" basketweaves from an RWD E30 on a E30 iX (manual trans)? I ask because I own a perfect set of 14" basketweaves with fresh tires, and my 15" iX rims and tires are in poor shape.
