Heads off
  • finch
    • Oct 2004
    • 279
    Heads off
    Well i warped my head.. i had been having some heating problems for a while.. then i forgot to put the radiator cap back on.. and yeah..
    so i pulled the head off.. had it shaved.. it was apparently 2 thou out :oops: want to get it ported/pollished along with some lighter valves but money forbids.. maybe
    does any one know, or can you tell, if this is a stock piston?
    some other pics..
    thats a scary sight. hope it all goes back together... :?
    painted my valve cover and intake manifold :D
  • trent
    Hmm....I thought 2 thou was alllowable. I thought anything over 4 thou was when it needed to be shaved.
      • 34844
      those pistons look stock to me (at least, they look exactly like mine).
      lots of people removing their heads eh? make sure you don't lose any of those head bolt washers (you got new headbolts, right!?), I gotta go search in the grass for one now. :(
      • finch
        • Oct 2004
        • 279
        Thanks.
        hmm that sucks. yeah new head bolts timinng belt gasket kit waterpump.
        i got told that 2thou was a fair bit.. but i honestly wouldnt know.
        • BS87
          • 1606
          I noticed the zip-tie T-belt... hope to go you aren't planning on re-using it.
          • EtaSport
            • 2853
            Ha, ive got pictures just like those. Mine are coming soon. 400k miles on stock block.
            I did the timing belt the same way, but still double checked it, I even had the white out mark (has less than 15k miles so no replacement). Your not reusing that head gasket are you?
            Old and improved:
            • pig4bill
              • Sep 2004
              • 122
              Once your timing belt has been tensioned, then the tension relaxed, you have to get a new one whether it has 40k or 4 miles on it, so sayeth the Bentley.
              Finch, are those the old head bolts in the pic with the valve cover? If so, lucky that you're replacing the hex head bolts before one of them broke on you.
              • finch
                • Oct 2004
                • 279
                haha surprised you guys pic up such fine details.. id hate to think of a world with out zipties..
                I am replacing the timing belt, although it only has about 25kms on it.
                Yes they are the old head bolts, the new ones are also hex head, but slightlt smaller..
                I heard somewhere that the m20 had two differant size timing belts..?
                is this true?
                • BS87
                  • 1606
                  :? switch to torx..
                  • arsevader
                    • May 2005
                    • 1025
                    Originally posted by finch
                    Yes they are the old head bolts, the new ones are also hex head, but slightlt smaller...
                    I'd be concerned about this, the hex head bolts aren't supposed to be available anymore.
                    is this true?
                    The older one was superceded with an updated design with a different number of teeth along with the tensioner.
                    • finch
                      • Oct 2004
                      • 279
                      Upon closer inspection they are not hexhead... my bad
                      Oh, and turns out the head was 4thou out, not 2 like i said earlier..
                      Old ones on the left, new right.
                      • arsevader
                        • May 2005
                        • 1025
                        Much better. Though out of the 3 types of hex head bolts that were used, only one kind was known to fail and even that was rarely. But better safe than sorry.
                        James
                        • finch
                          • Oct 2004
                          • 279
                          Is it worth getting port and polish done to m20? or wont notice a thing?
                          mild cam, headers coming soon...
                            • 34844
                            perhaps, if you don't need the car right away and you can afford it now. but if you're pulling the head later to put in a cam (you can't do it with the head in the car AFAIK) you could just wait.
                            replace those valve stem seals too! I didn't replace mine, they didn't leak before but the degreaser I used to clean the head must have cleaned all the crud out of them and now I get a puff of blue smoke when I start the car. fortunately you can do them with the head on the car, but it's much simpler if you already have it out.
                            • finch
                              • Oct 2004
                              • 279
                              well i dont get my licence back for another month, so i have the time..
                              I have the money..
                              And what i ment was, I already have a mild cam, and will be getting headers soon.
