I do them with a floor jack and removing/loosening the engine cross member. I have to do them again. I switching out my urethane ones. Sick of the vibe. Any better way? I don't have room to lift the engine high enough to pull them out.
How do YOU do motor mounts?
Past: 1987 325iS, Bilsteins - HR Sports
Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
put a plank of wood under the area where the block and trans mate, then jack up from there and put jack stands under the trans caseMy feedback:
http://www.r3vlimited.com/board/showthread.php?t=186328
http://e30tech.com/forum/showthread.php?t=74911
Instagram:
@gears_n_glory
@functionmotorsports
Originally posted by zebrafantastic View PostMa che cazzo state dicendo? :|
Unbolt mounts, jack up oil pan (with a board so it doesn't fail), put in new mounts, lower jack, tighten mount bolts.
Ich gehöre nicht zur Baader-Meinhof Gruppe
Originally posted by Top GearJust imagine waking up and remembering you're Mexican.
Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
Originally posted by T La View Postsorry to thread jack, but I was wondering how to go about lifting my engine up a little, my oilpan is a little close to the ground as of right now.
Originally posted by u3b3rg33k View PostUnbolt mounts, jack up oil pan (with a board so it doesn't fail), put in new mounts, lower jack, tighten mount bolts.
There motor is very tall and crushes the wire box just above the engine if I try to lift up the motor.Ma che cazzo state dicendo? :|
Originally posted by T La View Postthanks for the help <3 I knew I could count on r3v!
Now that I think about it, I've had 2 new engine mounts sitting in my trunk for the past 8 months. I should get around to putting those in.
Originally posted by jlevie View PostI just lift the engine with an engine brace.sigpic
Levent
%20levent@gutenparts.com
Ladies:
