doing guibo job
  • zandi
    • Apr 2004
    • 602
    doing guibo job
    Has anyone changed their guibo/flex disc before? How hard of a job is this actually, how long did it take you and how many people did u have to help you?
  • finch
    • Oct 2004
    • 279
    I looked at mine, then took it to a shop..
    • Jand3rson
      • 37587
      Re: doing guibo job
      Pretty easy job, you just have to remove a lot to get to it. It makes it worlds easier to do it if you drop the exhaust, but you don't HAVE to, you can just drop it at the rear and have it supported by something, it's just harder. Then, you remove the heat shielding above the exhaust, and unbolt the driveshaft. I'm pretty sure you have to unbolt the entire driveshaft, but I could be wrong. Then you just have to unbolt the old flex disc, replace it with the new one, and then it's just a matter of bolting everything back up. It helps to have one other person there with you, and it should take about 1-2 hours.
      • Digitalwave
        is a poseur
        • 6299
        Re: doing guibo job
        Done it at a leisurely pace in about 2 hours by myself.
        RISING EDGE
        • turnofftheradio
          • Apr 2005
          • 448
          I did it in an hour or so, but I didn't have any heatshields in the way. It is easy but slightly uncomfortable on the ground. perfect time to do a rear seal on the trans if it leaking.
          • nickmp0wer
            • 1427
            mine took me hours. I had the car raised like 4 inches on some wood i drove it on to and i had to keep getting out for differnt tools. I had to use an impact wrench to get the damn bolts off
            • Brew
              • 3060
              Should be like a 20 minute job. Get the car as high as you can and get two big crescent wrenches (17mm I think) on those suckers. Its six bolts- shouldn't take two hours.
              '91 318is
              • Digitalwave
                is a poseur
                • 6299
                I changed the CSB as well.
                RISING EDGE
                • Jand3rson
                  • 37587
                  I get to do that job AGAIN this weekend, after doing it about 3 weeks ago. Oh well, at least the right one will be in there this time.
                  Long story... :roll:
                  But while we were in there, we did both the rear tranny seals, rebuilt and replaced every bushing and clip in the shift linkage, and cleaned everything really well. PERFECT time to do any of those jobs if they need them, it's all super easy to get to with the exhaust down and the driveshaft out. Take advantage.
                  • zandi
                    • Apr 2004
                    • 602
                    Wish I could do the same but it's my first time doing it, I'm not familar with driveshaft and tranny at all, and so I don't know what needs replacing, I'm not sure what a CSB even is...is that the driveshaft bearing?
                    • Jand3rson
                      • 37587
                      Yes, it's the big bearing in the center of the driveshaft, where the 2 halves connect. If it's really worn, you'll want to replace it as well while you're down there. It's under $40, and not hard to change, you just have to have it pressed onto the driveshaft at a shop.
                      • Digitalwave
                        is a poseur
                        • 6299
                        I didn't have to have mine pressed.
                        RISING EDGE
                        • Jand3rson
                          • 37587
                          Really? How did you get it on? This would be helpful to me, since I have to change mine.
                          • Digitalwave
                            is a poseur
                            • 6299
                            I don't know, it just slid on...?
                            RISING EDGE
                            • zandi
                              • Apr 2004
                              • 602
                              I never use a torque wrench to torque my bolts, am I going to have to for the guibo? I'm just a little scared since this is the driveshaft we're talking about
