Does it ever bring up a check engine light? if so, what code?
Car can't drive when cold. only once warmed up. Misfiring when Warm....
i have the same exact issue and have for about as long as you.. i have tried quite a few different things as well with no luck...
one symptom that may or may not be related that i also see is after driving on the highway for a while (and i believe only in cold weather) the car will sputter when i floor it on the highway cruising.
I get a 1271 engine code, which means coil 1 I believe, but I replaced with a coil on plug conversion. same code spit out.
brand new 02 sensor less than 5000 miles.
ICV is working, you can see it flip open and closed.[/url]
Team USA Wrestling 67KG
Originally posted by Ryann View PostAs suggested above, I think you've got a vacuum leak somewhere. Find it. Check all hoses and gaskets that connect to the intake manifolds AFTER the throttle body. Also, injector o-rings.[/url]
Originally posted by JakeP View PostDoesn't really make sense if it only does the crappy idle when the motor is cold. If it was in intake leak, it would cause a crappy idle all the time.Originally posted by dkbmxer002 View Postwhy would leaks cause issues only when cold though...?
Originally posted by dkbmxer002 View Postwhy would leaks cause issues only when cold though...?The car makes it possible, but the driver makes it happen.
Originally posted by JakeP View Postlol. don't commit suicide yet. Maybe try checking the ohms on the DME temp sensor? unplug the ICV? Have you thought about posting this on m42club.com?[/url]
