Air Box
  • REO
    • Jun 2004
    • 14
    Air Box
    I was cleaning out the K&N today and noticed that there is a section of ducting that extends from the air flow sensor right to the edge of the box allowing only a thin opening for air to enter the intake ? ..... what the hell is the purpose of this? .... does it need to be there? ... if it was removed it should improve flow a great deal ....no?
  • erik325i
    • Jan 2005
    • 3567
    Re: Air Box
    Some people pull that piece out thinking it will improve airflow. I heard that it is in there to make the air less turbulent to the AFM. Air that is less turbulent flows faster, therefore allowing more air.
      • 34839
      leave it in. the .001hp increase you *might* get isn't worth the trouble.
      • etajohn
        • May 2005
        • 79
        Yes, the tube seems to come too close to the edge of the box, limiting ultimate airflow. However, it is a velocity stack and it provides a smooth path to the square opening of the AFM. That is another reason, besides the hot air thing, that cone filters don't do much on these cars. They don't smoothly taper from the round cone shape to the square opening. It's like putting on a bigger throttle body but not port matching the smaller opening in your intake manifold. Kinda pointless. Anyway, if you run the airbox, make sure the cold air part is hooked up and sealed correctly and leave the tube velocity stack thing in there. That's how it works the best.
          • 37832
          Because it's so hard to pop the thing out of there, lol :P
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • REO
            • Jun 2004
            • 14
            Hmm well piss on it then, I guess i'll just leave it in...
