What can I replace while my tranny is out?
  • 325is_e30
    • 567
    I just recently took my tranny out to replace the rear crankshaft seal. While its out what should I get to save myself trouble later on? I was thinking about getting poly mounts to put in. Maybe lighten my flywheel? What do you think?
  • cahomey
    • Mar 2004
    • 1201
    replace all your linkage
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
    • Jand3rson
      • 37587
      Some things to check while you're down there are:
      Flex disc
      Center support bearing
      Tranny mounts
      • permit
        • Mar 2005
        • 3363
        Might as well replace your reverse light switch ($10), you don't want that shorting any time soon and have to pull the tranny out again.
        • 325Projectz
          • Jan 2005
          • 1956
          Who needs a reverse light anyway. Put the 10 towards stiffer trans mounts.
          91 m3
          • 88325isboy
            • Mar 2004
            • 1058
            replace all the seals on the tranny and IE tranny mounts!
            '87 325 (Track Rat)
            '04 C5500 Wrecker (Work)
            '94 525i (Daily)
            '90 325i (R.I.P)
            H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
            • permit
              • Mar 2005
              • 3363
              Evidently, I don't.
              • EverWiser
                • Aug 2004
                • 313
                Replace the engine's rear main seal while you've got access to it...
                • Kilomph
                  • Oct 2004
                  • 599
                  How much would it cost to have somebody disassemble the tranny and replace all of the synchros I'm sick of that shitty notchy feeling from first too second and third. I'll hate it even more when I have a light flywheel and ssk.
                  • Jon325i
                    • 6934
                    I've been down this path before. It was when a clutch replacement was needed. Here's what I did while everything was torn apart....
                    new clutch kit (obviously)
                    throw-out bearing
                    lightened flywheel
                    UUC short shift kit
                    new tranny mounts
                    new guibo
                    new reverse light switch
                    starter (it was on its way out anyway)
                    The only thing I didn't replace was the rear main seal on the engine. If I had thought about it ahead of time, I would've taken care of this as well. I know my list may seem a bit much, but with the tranny out its a good time to address various things since its all readily accessable.
                    Of course if you like to pull the tranny every weekend, do each item separately :P
                    Jon
                    Rides...
                    1991 325i - sold :(
                    2004 2WD Frontier King Cab
                    RIP #17 Jules Bianchi
                    • 325is_e30
                      • 567
                      so the IE mounts make a noticable difference? also if i went the lightened flywheel route, would i have mine resurfaced/lightened? or replace with a whole new unit?
                      • 325is_e30
                        • 567
                        I was also wondering if there were any specs on how thick a new oem clutch disc is. My clutch works fine but how do I know if I should replace it or not, since I have it out now
                        • 325is_e30
                          • 567
                          bump?
                          • bebes2k
                            • May 2004
                            • 37
                            In case anybody actually wanted to know what the minimum thickness of their clutch disc is, according to Alldata:
                            "Minimum lining thickness of clutch disc: Lining surface up to rivet closing head - 1.0mm"
                            • 318isbmw
                              • Nov 2005
                              • 2841
                              I dunno y, I actually like doing the transmission, the bmw was a pain in the ass but I like doing it on my pickup, I've done it 4 times so far, no worries, I enjoy tearing stuff apart I guess
