What can I replace while my tranny is out?
  • Digitalwave
    is a poseur
    • 6299
    You can either have your stock flywheel lightened and resurfaced ($100-150) or buy an aftermarket flywheel ($350-450). The stock one will never be as light as an aftermarket, though.
    I would personally replace all these parts:
    rear main seal
    tranny input seal
    tranny output seal
    clutch kit
    resurface or replace flywheel
    clutch fork
    pilot bearing
    flywheel bolts
    clutch spring
    that little nub the fork sits on
    all shifter linkage (install SSK if you don't have one)
    tranny fluid
    reverse switch
    guibo
    center support bearing
    I did all these when I did my tranny swap. It costs about $450-500 for the parts from BMA, + the price of whatever you decide to do with the flywheel. You won't have to take your tranny out for the next 5-10 years if you do all this.
    RISING EDGE
