ABS light has been stuck on
  • moatilliatta
    • 6127
    <p>i had a dead battery. recarged it. and now i have abs (oragne telltale) staying on. anyone have any ideas why it has stayed on?</p>
    ________
    vaporizer reviews
    @Zakspeed_US
  • jht3
    • 288
    jump started it?
    check the abs over voltage relay thats clipped to the abs computer up under the instrument cluster. apparently the fusible link blows
    at least this is true for pre-1990 m3's
    James
    '88 M3
    • bichmgnt
      • May 2005
      • 42
      Same thing happened to me after I connected one of those self-charged battery jumper contraptions to my car with the key in the on position. Like jht3 said, you have to get under the dash to find the abs over-voltage relay.
      Pull the relay apart and look at it. There should be a fuse-like wire that's blown. Take the fuse part out of an 8 amp fuse and solder it in there. Put it all back together and the light should be out.
      Good luck.
      Steve
      Tomahawk -
      When you care enough to send the very best.
      • darien28
        • Jan 2004
        • 240
        replace your ABS relay... or micky mouse it w/ a new wire...
        • bimmer8604
          • 3017
          Originally posted by jht3
          jump started it?
          w3rd. i think there is a writeup somewhere, maybe on ben.
          Kyle
          1988 M3, 97 840, 99 XJ
          DILLIGAF
