Cluster swap. Gas gauge not reading correctly.
  • BenMGP
    • 210
    Hello all.
    Today I swapped out my cluster for one that had a working odometer and bulbs. I had a MotoMeter and swapped in a VDO. I did swap out the coding plug as well.
    Everything works fine except that the gas gauge is showing half a tank more than what's in there. I believe it is because the gauge itself is different and is not compatible with the sending unit? Do I have to buy a different gas gauge or will my MotoMeter swap into it?
    Is there an easy fix?
    Thanks.
  • bmwm42
    • 6300
    Should swap
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • mark_i
      • Feb 2011
      • 32
      swap the fuel gauge over. They are matched with either the 55L tank with one sender or the 63L tank with 2 senders.
      Just realised you guys still use gallons... do the math
      • FredK
        • 14762
        Yep, mark i is correct. You must have a 55L tank, but have a cluster from a 63L dual sender car.
        You can drop the gauge from your original cluster in. You need to undo the screws holding the two halves of the cluster case together, then remove a single 8mm nut on the back of the cluster that secures the gas gauge.
        • Kershaw
          • 11822
          ^ this.
          my e30 shows half a tank when its actually empty. full is still full. it doesnt bother me any.
          AWD > RWD
