Do I need new eccentrics and bolts for valve adjustment
  • clydesdale
    • 631
    I have never adjusted the valves and I have owned the car for the past 72k and it has 271k on the clock. Do I need to replace these parts or just adjust? Thanks.
    • 34844
    no, but I like to keep a few of the nuts/bolts on hand as sometimes they can strip. the eccentrics can also get flatspotted. You could replace them and it wouldn't hurt, but you don't strictly need to.
    • clydesdale
      • 631
      The flatspots, are they easy to identify? I hear they are more likely to occur in a situation like mine, where adjustments have not been made in a while. Thanks
        • 34844
        yeah, just pull a couple out and look at them. they would be pretty obvious if they are there.
        • clydesdale
          • 631
          ok, thanks. BTW, new valve cover gasket right?
          • blefevre
            • Dec 2008
            • 4287
            Yes, and the four plugs on the end.
            - E30, DSM, Golf R, Mazda 3 Skyactiv
            • clydesdale
              • 631
              I will take a look when I get near the car, but what plugs are you talking about? Thanks man.
              • blefevre
                • Dec 2008
                • 4287
                Four of these.
                http://www.pelicanparts.com/cgi-bin/...C%20Each%09%20
                • clydesdale
                  • 631
                  Thanks man!!
                  • clydesdale
                    • 631
                    Should I be good buying 3 eccentrics and 3 bolt/nut combos? The valves have not been adjusted in at least 75k. Thanks.
                    • netcsk
                      • Apr 2004
                      • 1609
                      If any are flat-spotted it is likely that all of them are. There are 12 total.
                      • Kershaw
                        • 11822
                        has the timing belt ever been changed?
                        if it hasnt.. i'd get on that.
                        AWD > RWD
                        • StereoInstaller1
                          GAS
                          • 22679
                          Fixed your post, bud.
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • Kershaw
                            • 11822
                            :rofl:
                            AWD > RWD
                            • clydesdale
                              • 631
                              Oh yes, I do the belt every 4 years. That is getting done at the same time. I kind of what to complete this start to finish, but not sure if I will end up having to order parts. Maybe I should buy 12 eccentrics.
