fucking Graf waterpump
  • Dave
    E30 RAT
    • 11675
    I bought it from BMA - trying to dig up my receipt. I just put it in a few months ago and I put very few miles on the IC. Now I get to take it all apart again!!! Emailed Patrick to see if they will replace it.
    At least it will be a much easier job this time since I don't have to do the t-belt again.
    To top it off, I am buying an eta next weekend and it needs a water pump too!!!!
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
  • kowalski
    • Jan 2005
    • 1791
    well you will be good at it then:)
    • PrinceE30
      • 282
      I just saw the thread :) Sorry to hear dude...that's rough!
      -prince
      Randall Prince
      http://www.rp1.us/ Used Cars
      • Dave
        E30 RAT
        • 11675
        -prince
        So I'll do two in one week!!!!
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • Dave
          E30 RAT
          • 11675
          Patrick @ BMA is going to ship me a new one. Good people!!!
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • hamann318is
            • 3382
            I hope you ordered a BMW OE pump.
            The BMW 318 is back. With a vengeance.
            • Digitalwave
              is a poseur
              • 6300
              I thought you had to redo the timing belt anytime tension was taken off it?
              I just put in a Meyle pump, hope it works out well. It's slightly leaking still and I don't know why but I know its not the pump's fault.
              RISING EDGE
              • rs4pro3
                • 5808
                If you do it right you do not have to detension the belt, you leave both tensioner bolts in tight and remove just the pump. It makes it hard to get the pump back in with that spring pushing on it but it can be done.
                85 325e 2.7 ITB'd stroker
                • arnoldgtr
                  • Mar 2004
                  • 153
                  I ruined a water pump gasket trying it that way. I found that it was much easier to install the water pump first, then the spring. You can compress the spring and hold it compressed with some needle nose Vise Grips to install it.
                  John
                  88 ///M3 Cinnabar
                  84 318i Black
                  • rs4pro3
                    • 5808
                    or some small zip ties work pretty good for compressing the spring
                    • Dave
                      E30 RAT
                      • 11675
                      Once the t-belt tensioner is tightened into place, isn't the spring kind of superfluous?
                      Current Cars
                      2014 M235i
                      2009 R56 Cooper S
                      1998 M3
                      1997 M3
                      • arnoldgtr
                        • Mar 2004
                        • 153
                        Yes, but you'll always know where to find it if you install it.
                        John
                        88 ///M3 Cinnabar
                        84 318i Black
