Crazy vibration when car is under moderate to heavy throttle
  • LikeCDoos
    • Jan 2004
    • 2522
    The past few days i've noticed a heavy vibration when i'm on the throttle. It started only in 2nd gear around 2900 rpm...now it's almost anytime I put my foot into it.
    The only things i can think of is a transmission or motor mount? I just changed my flex coupler about a month ago, maybe something could have come loose?
    Tomorrow i'm going to re-torque my lugbolts and look for tape weights missing on my wheels.
    Any ideas would be great guys, i hate when my car acts up.
  • AdamF 88iS
    • 2051
    Center bearing and/or u-joints on the driveshaft.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • Pieter E30
      • Jan 2005
      • 48
      Also check the balancing of your propshaft!! Had the same problem!
      • DaN
        • 1265
        Any loss of power? Perhaps some misfires?
        • rwh11385
          lance_entities
          • 18403
          • trent
            • darien28
              • Jan 2004
              • 240
              center bearing should be replaced with flexdisc IMO...
              • LikeCDoos
                • Jan 2004
                • 2522
                The car is going up on a lift tomorrow morning...i'll let you guys know the final verdict. I'm almost positive that it's the flexdisc and/or center support bearing.
                  • 34847
                  uh, that would last all of... 3 seconds before your driveshat exploded into a million peices. think about it.
                  in any case I'm glad my car doesn't have one of those things :P
                  • Axxe
                    • Aug 2004
                    • 3355
                    I think what he meant was you should replace the flex disc at the same time.
                    Keep it slideways!!
                    • Digitalwave
                      is a poseur
                      • 6300
                      You should know better than replacing the guibo without the CSB at the same time :)
                      RISING EDGE
                      • LikeCDoos
                        • Jan 2004
                        • 2522
                        guessed i learned the hard way... :(
