replaced lift pump with TRE-340, should i get rid of the external?
  • Gruelius
    • Oct 2009
    • 298
    hey all
    is it bad to have two high pressure pumps in series? ive gotta pull the pump to fix the soldering that got done failed
    anyway is 2 pumps better than one? ive been told its better to run one as the 2nd one could get rooted or something idk...
    if i convert it to a single pump id be just running 8mm over the top of the tank, will just have it as rubber hardline the whole way though.
    RIP 84 323i coupe 5spd w/ 14psi
    89' 318i
    • 34839
    no, it's fine. it actually makes life easier on the second pump. I'd leave it, especially if you have any future high HP goals.
    • Gruelius
      • Oct 2009
      • 298
      yeah cause i have 3 year old external, only concern of mine was the old 12mm line being run at high pressure. guess it makes sense to stick with the 2 pump setup.
      89' 318i
        • 34839
        just make sure the fuel hose is new and rated for fuel injection and it will be fine.
        • Gruelius
          • Oct 2009
          • 298
          problem chief, doesnt that 12mm hose need the tank to be dropped to be changed?
          i could see myself snaking 8mm hose above the tank but 12mm?
          89' 318i
            • 34839
            pretty sure all the hoses that go between the tank/car are hard lines and the rubber hoses just connect to them?
            • Gruelius
              • Oct 2009
              • 298
              nah the transfer pump is a 12mm rubber hose that runs the full length of the tank which SUCKS otherwise i would have replaced that shit!
              89' 318i
                • 34839
                if it's in good shape I wouldn't worry about it too much. it's already FI rated.
                • Gruelius
                  • Oct 2009
                  • 298
                  yeah, i hate the crimp clamps they have on the line, but if those are FI rated itl be sweet. but yeah no fraying/cracking/bulging on the old line.
                  89' 318i
                  • Gruelius
                    • Oct 2009
                    • 298
                    decided ill just go the single tre 340 for peace of mind.
                    Does it matter that there is no flared fitting when putting it into the series 2 pump holder? shit looks ghetto as
                    or is it dangerous to just have 8mm hose flopping about above the tank? i dont got no hardline above le tank
                    89' 318i
                    • Gary Horneck
                      • May 2011
                      • 435
                      I have the same fuel pump. What size hose is that connecting the pump to hard tube? The one that came with the TRE split. The outlet on the pump is a smaller than the tube so it was a stepped fitting, and I can't get fuel line to fit tight on pump outlet if it fits over the hard tube.
                      2011 335i/1995 Mercedes C220 (rallyx)
                      • immajackuup
                        • Dec 2010
                        • 1132
                        so the fuel pump was like yo lets increase the operating pressure to approximately 3 BAR and then the fuel was like fuck your couch nigga im gettin the fuck out this mothefucker
