A/C from R12 to R134?
  • ///Bimmerfan
    • Dec 2008
    • 730
    Has anyone had any luck converting there R12 system to run R134?
  • bmwm42
    • 6300
    Ya took it to bmw to be retrofitted.
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • ///Bimmerfan
      • Dec 2008
      • 730
      How much did that cost you?
      • bmwm42
        • 6300
        Nothing lolz previous owner took care of it but quick rundown on what you'll need new evaporator o rings and pump thats pretty much it
        • ///Bimmerfan
          • Dec 2008
          • 730
          Ok Thanks
          • '89e30
            • Dec 2008
            • 71
            you cant use R134 in the e30 system?
            • ///Bimmerfan
              • Dec 2008
              • 730
              Thats my question also.
              • enigmaticdream
                • Jan 2010
                • 572
                Freeze 12 is your friend. It uses the R12 system, legal, and cheap.
                1986 911 Supercharged Frakenstrat/Stripped
                1987 325is Delphin/Black (Olga)
                1988 M3 Zinno/Natur (Elsa)
                Manual or STFU
                E30 Chapter of BMW Car Club of America
                E30 Oktoberfest 2017
                • redsubdivisions
                  • Feb 2011
                  • 1762
                  I converted mine over to R134 last weekend. Just change the drier out and you should be good to go.
                  1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                  2012 Passat TDI - DD Duty
                  2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                  • Cong405
                    • Jul 2009
                    • 590
                    IIRC, you also need to check and make sure your ac compressor is capable of using the R134 too.
                    Please correct me if I'm wrong, but certain compressor (newer model e30) can handle both R12 and R134 and some can't. I think there's a thread about it somewhere in the forum. I'm pretty sure if you search, you'll find your answer.
                    • redsubdivisions
                      • Feb 2011
                      • 1762
                      Oh, and if you have access and experience to an A/C machine, I recommend pulling vacuum for 30 minutes, inject oil (1 or 2 oz should do), then charge up a little over 2 lbs of R134 and you should be good to go.
                      • bmwm42
                        • 6300
                        As usual leave it to a noob to answer with a stupid nonsense reply.
                        Get ur facts checked before you post a stupid reply.
                        • Ryann
                          • 3350
                          Your best option would be to use Hot Shot with your existing system imo. It is 100% compatible with the e30 compressor and expansion valve and designed to be a drop in replacement for r12.
                          The system first needs to be charged with dry nitrogen in order to find leaks. If your system has been non-operational for a while it'd also be a good idea to replace the filter drier assy. with a new one. After leaks have been located/fixed you'll need to use a vacuum pump to pull the system down to at least a 1000 micron vacuum, at which time you can recharge it using Hot Shot.
                          Bear in mind this info is only good if your problem is simply that you've lost your refrigerant charge. There are other problems that could cause your a/c to quit working.
                          • KenC
                            King of Kegstands
                            • 14396
                            You can, but it won't work well at all. Provided your R12 system is/was functioning properly, it'll work if you just put R134a in. Ideally you should replace your receiver/dryer.
                            The biggest problem is that the compressor is undersized for use with R134a.
                            Just find R12.
                            Originally posted by Gruelius
                            • mutty
                              • 290
                              [quote=Ryann;2529534]Your best option would be to use Hot Shot with your existing system imo. It is 100% compatible with the e30 compressor and expansion valve and designed to be a drop in replacement for r12.
                              You do refrigeration work? The only sensible option exposed on any forum about r12 options. Smart.
