no start after timing belt install
  • E30MACK
    • Dec 2009
    • 230
    ok so I replaced the timing belt, tensioner, thermostat, waterpump, cam gaskets, all belts, new radioator, new coolant.....bla bla bla, I go to start it and no go. I made sure all the timing marks lined up before I put everything together. any suggestions?
  • ak-
    • 12422
    Explain the bla bla bla. Could be important
    1991 325iS turbo
    • b*saint
      • 3794
      I would start by retracing your steps you took to remove everything. Obviously its something you did or forgot to do.
      Ma che cazzo state dicendo? :|
      • LJ851
        • 7919
        Reinstall the ignition rotor? TB job is pretty simple, you must have disconnected something and not reconnected it.
        Lorin
        The M30 is God's engine.
        • billybobjoseph
          • 213
          Start by checking fuel and spark - go from there.
          • E30MACK
            • Dec 2009
            • 230
            i guess the bla bla bla would be the ignition rotor...I think thats the only thing I left out. I did replace a hose clamp on the the intake system, but that was just take one off and put it right back on. would a timing light tell me if my timing is off with out pulling everything back apart?
            I didnt change anything with fuel and the only thing i changed with spark was the ignition rotor.
            • IveGotIssues666
              • Oct 2006
              • 517
              Is it a late model E30 with a crank sensor? If so did you disconnect it? Did you mess with the spark plug wires at all on the cap itself? If so you could have them in the wrong order...
              • E30MACK
                • Dec 2009
                • 230
                its a 88' 325is with a crank sensor which i took off and reconnected. I didnt unhook the plug wires at all just the distributor cap with everything connected still.
                • gp.plus
                  • 416
                  You may have the cps and cylinder identifier plugs swapped, they look the same.
                  • moatilliatta
                    • 6152
                    Do you have spark and fuel? What kind of vacuum numbners are you getting?
                    @Zakspeed_US
                    • E30MACK
                      • Dec 2009
                      • 230
                      haven't checked vac numbers yet, have spark and fuel. dunno about the cps and cylinder identifier plug....im pretty sure i didnt switch those though.
