Belts squeeking
  • Digitalwave
    is a poseur
    • 6300
    Belts squeeking
    My belts squeek (probably the v-belt) early in the morning before the car is warmed up. After its warmed up it stops. It's a wretched squeek, that gets louder up till 2k RPM's then goes away till the revs go below 2k again. I've tried belt dressing and it didn't help. The belts are brand new. Does this sound like I made them too tight, or too loose?
    RISING EDGE
  • EverWiser
    • Aug 2004
    • 313
    Go a smidge tighter; see if that helps...Also, if it's your alternator belt make sure your alternator bushings are in good shape. They could be letting it move around a little.
    • E30godz
      • 1524
      mine do too....sometimes when turning randomly as well...odd
      • nickmp0wer
        • 1427
        if they are squeeking they are slipping=too loose. I think
        • Dominick
          • Aug 2004
          • 323
          dont ever put those belt dressings on your belts, tighten them up a bit
          www.ThundaCats.com
          • RobertK
            Kicked cancer's ASS.
            • Jun 2005
            • 5864
            Sometimes pulleys can develop a glaze over time that makes it harder for them to grip the belts. You may want to try taking some 100-150 grit sandpaper to the inside grooves of the pulley to help them grip the belts better. I've also heard that rubbing the belt with a bar of soap works to but I've never tried it before.
              • 34847
              could be stripped out tensioner nuts.. they are pretty soft and are destroyed easily. take them off and inspect them.
              mine used to squeak exactly like you describe (all new belts), but I always knew the tensioner nut for the alternator was stripped. once I replaced it the squeak went away.
