Bosch 525 vs 173 ecu
  • Sputnik
    • Jan 2010
    • 808
    I was about to install a freshly-ordered 173 chip, and than I quickly realized that the last three digits were 525!
    Should I just find a 173 to put in, or keep the current ecu and exchange the chip for another one?...
    Btw: car is a '91 325i/s
  • wodcutr
    • Apr 2009
    • 2193
    That chip will not work in the 525 as it is a motronic 1.1 and the 173 is a motronic 1.3. Your car should have had the 173 in it so the ECU has been changed from the original. I have a good 173 if you decide to buy one. PM me!
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
      I'm sorry, but that is not correct. Both the 173 and 525 are Motronic 1.3, with the 525 being a later version of the DME. The 525 would be the DME that would have come in a 91 325.
      I don't know if you can use a chip meant for a 173 in a 525.
      • Adrian_Visser
        • Jun 2006
        • 2823
        I was using a chip meant for a 173 in my 380 DME before it died. Iirc I read somewhere that the later DME's know more fault codes and using the 173 chip takes that ability away.
        '89 Alpine S52 with goodies
        • Sagaris
          • Sep 2009
          • 2243
          I am using a 173 chip specified for a manual trans car (even though the ZF 4HP22 isn't electronic) in a 524 DME. All is well.
          • wodcutr
            • Apr 2009
            • 2193
            I stand corrected! I always thought that the 525 ECU was the early version that came in the 87/88 i's. Most people don't want the 525 for that reason and always prefer the 173 over any ECU. I have heard that the 525 has better idle software in it. Maybe the 525 is a better ECU than the 173, but if they are both 1.3 then they should be able stomp test codes either way. I think I may just try my spare 525 ECU and see how she works! :)
            • scottinAZ
              • Dec 2009
              • 1312
              you are thinking of the 153 moronic 1.1 ecu.
              I saved 15% on my Bimmer parts by switching to ...
              • Sputnik
                • Jan 2010
                • 808
                Thanks for the help guys, but brody cleared it all up for me.
                If anyone knows, what was the purpose of bmw having three different ecu's for the same year and model????
                  That was simply technology evolution.
                    • 34839
                    There is very little difference between the two, if you put them side by side they are identicle.
                    Your chip could work fine, its worth a shot. The worst that could happen is you trigger a CEL.
                    • mach schnell
                      • Apr 2008
                      • 1059
                      Old thread, I know.
                      What’s the difference between a 173 ECU and a 525 ECU?
                      Is it true that the 525 ECU is the later, better version... ?
                      And is a 525 ECU a direct plug n play replacement for a 153 ECU? (I have an ‘88 with a 153 that I want to swap out)
