what would cause a clunk when you let off the gas...
  • natorious
    • 672
    so my car has no rattle or clunks or anything except one... when you let off the gas it clunk but only then not over bumps or anything
    oh and it only does it when i let off the gas all the way if i let of slowly it doesnt do it... i think it does it when the tranny shifts when braking too
    so its like vrrroooooooom-clunk-vrooooooooom-clunk
    btw its a slushbox
  • rwh11385
    lance_entities
    • 18403
    if you let off the gas quickly and there's a clunk you feel, it is most likely the guibo aka flex-disc
    you should have that replaced.
    same thing on my car, costs about $30-40 dollars. (the part that is)
      • 34847
      might be motor mounts too. or subframe/trailing arm bushings. there's a bunch of things you should check.
      • backlife
        • 104
        nope, that would most likely be your u-joints when the flexdisk is going out it causes a rattle-clank-thunk under your shifter when you accelerate
        -adam
        • 325eowner
          • 6
          i bet it's your differential, mine does the same thing. my mechanic said it's from play inside it. gonna be replacing mine in the not too distant future.
          • Bryson
            • 1490
            this is definitely the loudest, most heavy of them all.. could be the diff and/or diff bushing also. A broken center carrier and fucked up flexdisc can make jumps, as can tranny and motor mounts (motor mounts displacing the drivetrain)
            turn on your AC, the clunk will get much more predominant at freeway speeds, try on/off gas a few times until you can locate the general area of the thunk, then get back to us.
            If he's lowered/drives hard, I'm betting subframe/t-arm bushings
            • E30godz
              • 1524
              mine does this very badly too...and my engine mounts and tranny mounts are totally fucked...i plan on replacing them shortly
              • natorious
                • 672
                i am gonna try and find where its comming from on my way to work today...
                i'll get back to you in a bit....
                but as of now i definatley think its something in the back
                more info:
                car is bone stock
                was NEVER driven hard until the last week (already had the clunk)
                but was driven on new york/new jersey roads meaning not exactly the smoothest.. think surface of the moon
                • darien28
                  • Jan 2004
                  • 240
                  is it like a hard clunk that you can feel and seems to come from the rear and under your car? i had the same problem... changed tranny mounts, guibo, center support bearing... and it all went away.
                  • PeterCip
                    • 402
                    Check the status of your diff bushing before anything else. while under accel your dif torques up against the car, only to fall back down with a clunk when you let off the gas. ask me how I know...
                    • bwanac
                      • 3354
                      That is the problem I have, worn diff bushing. Really need to fix it, but I can handle it for a little while longer!
                      • natorious
                        • 672
                        i am thinkinking its the bushin on mine as well but i havent gotten under there yet to get a closer look
