need help ASAP, fuel rail Question
  • bmwannabe
    • 900
    Alright, im doing my fuel injector seals, and i dont know how to get the fuel rail off, i have my intake manifold off now, but im not sure how to start dis assembling the fuel rail, and how the injectors come apart. do i need any special tools? it looks like it all snaps apart, but before i start pulling on vital parts i want an answer. any help appreciated
  • De //m3
    • 165
    The little metal clips can be pulled back on the electronics that go to the injectors. Once you have everything disconnected from the rail except the injectors, just pull the rail out. The injectors will probably stay connected to it, and then you just pull them out once the raill is out of the car. If the rail comes out without the injector, just pull the injectors out next. Be aware that fuel will come out of ther rail as you're disconnecting hoses, so either clamp them first or wipe it up later.
    2001 330i - In the garage.
    1986 335is - 325e with Euro 735 M30B34, Under Construction.
    1989 E30 ///M3 - Sold.
    1975 2002 - Sold.
    • bmwannabe
      • 900
      do you mean i can unclip the little square clips? i just want to know the easiest way to get the injectors so that i can install the seals.
      • E30godz
        • 1524
        i thought you could remove the injectors without removing the intake manifold?
        • bmwannabe
          • 900
          wow. thats great to know now
          • De //m3
            • 165
            I have an M3, so Im ot sure if you have to remove the intake manifold or not, but yes I mean the little square clips, they slide back but dont come fully off. They allow the electronics to be unplugged. Once theyre of you dont even have to disconnect all the lines to the rail. Just pull it off, pop out the injectors, change the seals and pop em back together.
            1975 2002 - Sold.
              • 34839
              yes, you can, and it's not very hard.
              • formula driver
                • 2263
                ouch.........
                Yea its easy to do with the intake manifold in the car. Just remove the valve cover and you got all teh room you need. As for doing it teh way you have, pull the bolts that hold the rail in all of teh wiring harness(label), pull teh clips of (flathead worked fine for me, and then pull the damn thing up. You not in any real danger of hurting anything but just dont put to much force when pulling up on the Rail. Hope this helps.
                -Paul
                • bmwannabe
                  • 900
                  lol, 10 hours later im done. broke off one of my sensors on the thermostat, and forgot to bolt the fuel rail back onto the manifold. jeeezus i am a dumb motherfuker. lol lesson learned.
