Machining wheel offset
  • Mafiaracers
    • 353
    I'm in love with the Rota Grid V wheel...but I've got some questions/concerns and would like your thoughts.
    The grid v is offered in 15x7 and 15x8 in both 20 and 0 offsets for each.
    However, the 0 offset (on both the x7 and x8 ) has a deeper, stepped, pronounced dish that I really like and would prefer. I would run a 225x50x15 tire on either width.
    The question is, if I want the 0 offset wheel for the dish, but fear the potential poke, is it possible to mill down the hub/mounting face to effectively tuck the wheel back into the car?
    Realizing I'd have to be dead nuts perfect flat on the mill to avoid the risk of an uneven cut....measure 18 times and cut once, does this sound feasible?
    Chris Woods
    https://www.facebook.com/munichmotorworks
  • Eric
    • 5142
    no.
    • Mafiaracers
      • 353
      like this
      Chris Woods
      • Dj Buttchug
        • Jun 2010
        • 7688
        fwiw 0 offset doesnt poke if your low...
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • LJ851
          • 7919
          ^ Listen to the Butt.
          Lorin
          The M30 is God's engine.
          • Jaxx_
            • Dec 2009
            • 1880
            you can do it, but the problem is if you cut too much you will damage the wheel so that it will fail under hard loads. it will fail at the hub/lug holes. I wouldn't do it unless you had a lot of meat to work with on the hub.
