Turbo e30 running to rich
  • Lrutts
    • 104
    So, i have a turbo e30 with a very low boost setup, around 8psi.
    I have run into a fuel issue. It runs so rich! But only when i first step on the pedal. Then settles down a bit. But still poors fuel smoke out the back when accelerating when not under boost. Its much worse when the engine is cold, but still does it a bit when the engine is hot. It idles at 14.8 A/F but its having troubles when i give it any throttle, almost like it has a vacuum leak, but i looked everywhere for one.
    Too small? Blood Sweat and Tears Build:
    http://www.r3vlimited.com/board/showthread.php?t=202389
  • Dj Buttchug
    • Jun 2010
    • 7683
    what engine mngmnt?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Lrutts
      • 104
      Originally posted by Dj Buttchug
      what engine mngmnt?
      Lol...... ummm, i have an ebay timing chip. And played around with the AFM. But i have ran this for a year, never gave me an issue. This just started last week.
      • Jaxx_
        • Dec 2009
        • 1880
        can you give a little more info on your setup? I would start checking for boost leaks but that would mean that you're lean when not in boost and rich when in boost, not the other way around. you might have a leak post AFM but before the turbo. PCV system or similar maybe?
        (It's late so I might be thinking this out wrong...)
        • Lrutts
          • 104
          Well, its an ebay turbo setup, I have had a ripped intake boot before, and that just makes it rich all the time. I have looked for leaks but can't find any. Maybe i should do a smoke test. Does anyone know where you can buy something to do a smoke test? Or how to make your own?
            • 34844
            Well there is your answer.
            • Lrutts
              • 104
              So that tells me why this just started?
