how much of the rear firewall can safely be removed...
  • natorious
    • 672
    how structural is it...
    pic of said item (not my car)
    i want to trim away some of it for subwoof enclosure reasons...
    i was thinking maybe trimming away an opening a few inches wide on either side of the two vertical "bars" in the middle and maybe welding in some expanded metal to keep some of the rigity of it... or maybe welding in some bracing from the back...
    thoughts or experience with this would be helpful.. thanks in advance... and this is just me brainstorming...
  • Rob
    • 8166
    if you weld in some bracing of some sort (square tubing?) I think you'd be fine.
    BEERTECH
      • 34844
      the panel in the center there is for a ski bag, you can punch that out without affecting its structural integrity.
      • trent
        You can probably cut most of it out and not notice a thing.
        • BMW BMXER
          • 2325
          You could do it...
          DTM Powa style!
          Sold it.
          • natorious
            • 672
            i can promise you one thing anything i trim off wont be anything even sorta close to that much
