Auto shifter removal?
  • GunMetalGrey
    • Dec 2010
    • 1499
    How do I get the automatic tranny's shift "knob" off? Tranny needs to come out, any other info would be lovely.
  • LJ851
    • 7919
    It has a set screw near the bottom of the handle iirc.
    Lorin
    The M30 is God's engine.
    • scottinAZ
      • Dec 2009
      • 1312
      +1 front side of the handle there is a setscrew that you need to remove. easy peasy
      I saved 15% on my Bimmer parts by switching to ...
      • bloodshot-e30
        • 1494
        saw zaw, torches, and a big hammer
        ^Back in the game^
        BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
        FS thread:
        http://www.r3vlimited.com/board/showthread.php?t=214105
        • scottinAZ
          • Dec 2009
          • 1312
          fuck that, too much work, coupla hundred feet of detcord should do the trick though.....
          • bloodshot-e30
            • 1494
            lmfao yea that should work too... hahahahahah
            i really did use the saw zaw getting mine out tho
            ^Back in the game^
            FS thread:
            • austin01
              • Aug 2011
              • 1
              Check this website: Check this website: http://www.formymercedes.com/Shift_K...ather_Boot.asp
              Defensive Driving Texas | DMV Practice Test | Driving Record
              • Holland
                • Nov 2008
                • 7212
                Power shift from first to second pulling really hard... wait what?
                Originally posted by DEV0 E30
                  • 37833
                  You shouldn't have to remove the shift "knob" to do the tranny.
                  If you're swapping an auto for an auto, you can leave the whole shifter assembly in place. Unclip the single selector rod from underneath. If you're doing a 5 seed swap, you can remove the whole shifter assembly in one piece minus the decrotive cover that goes over the console.
                  Grover Beach, California
                  BimmerHeads.com
                  • GunMetalGrey
                    • Dec 2010
                    • 1499
                    ^this, found out that you can just unclip the little rod going down. Thanks though!
