check the alternator light?
  • chuckybob
    • Aug 2004
    • 952
    im troubleshooting a charging system problem, and the bentley told me to check the alternator light on the instrument panel. the problem is, i dont have an alternator light on the instrument panel, and no one i know seems to have one either. any ideas as to where it might be located, or did bentley make a really big typo?
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
  • reelizmpro
    • 9558
    It's not in the check panel but the instrument cluster...it's the little battery light. It comes on when the battery isn't being charged by the alternator. If you're cluster is a pre 86, a bad "battery light" bulb will cause the alternator to not charge the battery. Later clusters, were updated with a type of bypass circuit that got rid of the problem.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • AdamF 88iS
      • 2051
      I think they all do it actually.. I had an 88 cluster that did it too.
      If your warning light is burned out or missing it won't charge,
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
