removing stock CAB lollipop from control arm?
  • lolcantturn
    • 4588
    I can't seem to get the stock CAB off of the control arm. tried kicking the shit out of it and it didn't budge. Any tips or anything?
    Originally posted by TSI
    OEM+
  • Todd Black 88
    • Oct 2007
    • 3449
    Pullers, or press.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • lolcantturn
      • 4588
      Originally posted by Todd Black 88
      Pullers, or press.
      I'm talking about actually removing the lollipop with CAB from the control arm, not the CAB from the lollipop. I already have M3 bushings pressed into a lollipop
      OEM+
      • LJ851
        • 7918
        I just did this. Major pain in my ass. What i did was centerpunch the end of the control arm to locate my 2 jaw puller and pull on the OD of the lollipop. This did not remove the bush for me but separated the bushing. Once the lollipop was off with the outer half of the bush i slit the inner metal sleeve with a cut off saw and removed it.
        Lorin
        The M30 is God's engine.
        • lolcantturn
          • 4588
          this is exactly what i was planning on doing. time to get some cutoff wheels for the dremel.
          OEM+
          • Todd Black 88
            • Oct 2007
            • 3449
            Yes i know. I used a puller and it worked fine. You want to reuse your cab and lollypop right.
            2010 F650gs twin
            • Kershaw
              • 11822
              i used a sawzall. cut the bushing apart, took the lollipop off. the rest of it came off really easily then.
              AWD > RWD
              • Todd Black 88
                • Oct 2007
                • 3449
                Sorry, its not a three or two jaw style, it looks like this pic.http://http.cdnlayer.com/ec1images/2...1000038535.jpg
                Worth every penny.
                2010 F650gs twin
                • Hellabad
                  • 807
                  Try this
                  Do this with the control arm bolted the car.
                  Unbolt the two bolts.
                  Liberally spray the inside of the bushing with JB80 or some kind of oil (wd40 last choice, but it works)
                  Go do something for 10 minutes.
                  Grab the handle of the lollipop and twist and twist until it breaks free and then wiggle it off.
                  Jay
                  Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                  Ground Control Gallery
                  The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                  • Unearth078
                    • May 2008
                    • 2623
                    Jay
                    qft. while control arm is oily, put new ones on. ps lemme get my strut housings. they will be needed soon for my GC goodness.
                    Originally posted by Lof8
                    4 doors allow you to transport more whores.
                    therefore, their value is much greater.
                    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
