I have an 87 cabbie with the m20. Problem is my AC works fine and is charged and holds as well, but its not as cold as i think it should be.. Maybe the compressor needs to be chaged or maybe something else. Any thoughts please??? Thanks guys..
AC not cooling enough.. What needs replaced???
From my understanding, if you put r134 into an r12 system it will never be as cold as it was originally. If it blows colder on the freeway I would also look at the fan clutch.Comment
USUALLY the r134a conversion doesnt work so well because people dont fully convert the system or cut corners. however, i've been in a few e30s that ran r134a and were ice cold. however, they overhauled the entire ac system.AWD > RWDComment
Your right. I didn't on my car. Just changed the fittings. It usually blows about 50ish degrees instead of 30ish. And when it's 100 outside, 50 usually suffices. :) My fan clutch is weak though and it doesn't work as well in stop and go traffic.Comment
