overheating issues
  • RUFFLZ
    • Apr 2011
    • 3122
    overheating issues
    my e30's temp gauge is constantly tipping past the median and is at 3/4 while in idle. However, car runs cool when i'm driving it.
    having to constantly turn off/on the car at long stop lights and drive-thru's gets old fast.
    anyone know what the problem may be?
    Ameet
  • accident
    • 7303
    clutch fan?
    Moral of this story?
    • graphikg
      • Jan 2008
      • 1614
      Let it cool down and bleed it again. Same thing happened to me unless it is the clutch fan or even h20 pump.
      • E30_fiend
        • Apr 2006
        • 7348
        Im with Greg. Fan clutch would present those symptoms. As would air in the system. Clutch is more likely though
        • RUFFLZ
          • Apr 2011
          • 3122
          Originally posted by accident
          clutch fan?
          already bled the system, clutch fan it is
          thanks d00ds
          • bmwm42
            • 6300
            dont rule out a shity water pump
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
            • Dj Buttchug
              • Jun 2010
              • 7639
              its not the water pump. its lack of air flow.
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • accident
                • 7303
                If it was the water pump it would over heat while moving too. The engine cooling down at speed suggests the radiator isn't getting any airflow.
                • bmwm42
                  • 6300
                  Well if something is restricting water flow broken impeller etc the fucker will run hot and of course will cool down travelling at highway speeds
                  • accident
                    • 7303
                    No, if the water isn't flowing then the cooled water from the radiator wont be circulated, and the car will overheat while moving as well as at idle.
                    • E30_fiend
                      • Apr 2006
                      • 7348
                      ding ding ding
                      The waterpump HAS to flow water. If it restricted at all, it doesnt matter if you are sitting still or doing 200mph, its still going to get hot.
                      OP, if the fan clutch isnt the problem, take your radiator out and either take it to a shop for a thorough cleaning or clean it out yourself. Word of advice when cleaning, always use the dry method first. If there is dirt in the fins of the radiator and its giving it flow problems, adding water will create mud which will make your problem worse. So blow it out first, then when yo can see through most every fin in the core of the radiator, THEN spray it out with the hose.
                      Good luck
                      Taylor
                      • russianman92
                        • May 2011
                        • 53
                        Could be your thermostat mate
                        If its a bad thermostat could not be circulating properly creating blockage. Had a problem like that with a customers 528i when at idle it got hot but when moving temp dropped.
                        • accident
                          • 7303
                          This is an air flow problem, not a water flow problem.
