HELP! M30 AFM PROBLEM!!!
    So i bought a m30 afm a 027. And i install it and everyting goes ok. Except that it wont rev past 5k without hitting a limiter. What should i do? Swap out the boards? Also when you swap out the boards do you swap out the connector also?
    It's probably horribly out of adjustment, as it always is when people throw them in without a wideband.
    Do the R3V thing, and play with the wheel until you think the A/F is correct.
    Or, do it properly, and get on a dyno with a wideband and tune it right.
      messed around with it for a bit. And then i noticed a rock stuck in it. So it didnt let the little thing slide all the way across. Now it works perfect no elctronics swap or anything. IM such a noob.
        don't do this. afms are lazer toleranced and you'll likely fuck it up if you do.
