High beams stuck?
  • dubseven
    • Jul 2011
    • 382
    High beams stuck?
    86 325ES
    With low beams on, no headlights. Turn on high beams, and both high+lows come on. Anyone ever had this issue?
    Check the low beam relay, headlight switch, and dimmer switch.
    • CabbE30
      • Aug 2009
      • 2358
      Lol.
      Replace both low beams. But before you do that make sure you're receiving power there.
      This is one of the most commonly asked questions on r3v.
        • 34827
        your low beam bulbs are probably dead, sealed beams are dual fillament.
        also:
        -the little triangle thing on the back parcel shelf is a turbo air duct.
        -the little vent thing on the heater console is a top secret spy microphone
        -if the "check" light on the dash lights up when you turn on the car, along with the "brake light" bulb on the check panel, your motor is gonna explode.
        :p
        • Sagaris
          • Sep 2009
          • 2243
          also:
          :p
          Quoted for truth.
            • 37828
            Finally some solid advice from nando. :D
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
              • 34827
              <3
              • turge
                • 2576
                Have you tried replacing your headlight fluid? This is a common problem if not addressed. :razz:
                • dubseven
                  • Jul 2011
                  • 382
                  LOL guys ;)
                  I have DEPO projectors, hi + low are separate?
                  • accident
                    • 7303
                    To be quite honest, I STILL don't know what this is.
                    Moral of this story?
                      • 34827
                      Originally posted by ar design
                      LOL guys ;)
                      you wired it wrong
                      you need to wire the low beams into the lowbeam power wires. then you need to add a jumper wire between the two relays to keep the lows on with the highs.
                      right now you have both lights wired to the high beam power wires instead (the lowbeam pigtail has both).
                      • accident
                        • 7303
                        Every time I do an ellipsoid conversion I just put both lowbeam power wires into the one for the ellipsoid low. Keeps you from having to fuck with the relays.
                          • 34827
                          yeah, but then you're backfeeding voltage into the high beam circuit. the jumper is really easy, just put a peice of wire into the slots for the correct pins, and push the relays over top.
                          • accident
                            • 7303
                            Isn't that part of the high beam circuit dead when the relay isn't switched on, though? I mean I guess over time it COULD fry the high beam relay, but I've never had an issue with it.
                              • 34827
                              yes, maybe, but you never know the side effects of something like that.
