Found the source of my trunk leak...but need a solution!!! (Gas door stopper)
  • audiquattrot
    • May 2008
    • 3836
    sorry, posting here as well for more views (posted in 'Body & Paint')
    So I've been trying to track down a leak underneath my battery tray...replaced my c-pillar trim gaskets + taillight gaskets....but it still leaked a little after that.
    Took a hose to it, and realized it was coming from below.
    I had my car painted a couple months ago, and they forgot to put this gas door stopper in (held in by two screws). I sourced the missing piece from my friends' donor car that we scrapped. Problem is, the screws don't have a female nut in the body of the car to hold them in. So it slides right in w/o having to screw.
    Question is, what am i missing?? I tried to look on the back side (inside the trunk) and can't gain enough vision to see whats missing. Gaskets? bracket inside the trunk?
    Any possible solutions you guys recommend? I was thinking of siliconing the holes for now, but the problem with that is, the pin lock would still allow water to get into the trunk since there's a gap around the pin. I'm also contemplating (if there is a way), to disable the gas door pin from locking...and siliconing around that as well.
    HELP! LOL
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • audiquattrot
    • May 2008
    • 3836
    would be great if someone can unscrew theirs for me, to see if they can see anything.
    #snwmble
    Current:
    Past:
    • audiquattrot
      • May 2008
      • 3836
      am i missing #25? I'm trying to figure if #24 is the gas door pin....b/c if so #24 & #25 part numbers are no longer available.
      #snwmble
      Current:
      Past:
      • Holland
        • Nov 2008
        • 7212
        25 is that black piece you already have, mine is identical.
        Originally posted by DEV0 E30
        • audiquattrot
          • May 2008
          • 3836
          thanks. I need to find out why the screws aren't screwing in now. Doesn't make sense. I removed it from an E30 that #25 screwed into fine.
          #snwmble
          Current:
          Past:
          • audiquattrot
            • May 2008
            • 3836
            bump...anyone?
            #snwmble
            Current:
            Past:
            • frankenbeemer
              • Sep 2009
              • 2260
              I'll go outside (it's raining) and check my 4 door shell, but you owe me.
              Don't buy an e30
              They're stupid
              1989 325is Raged on then sold.
              1988 325 SETA 2DR Beaten to death, then parted.
              1988 325 SETA 4DR Parted.
              1990 325i Cabrio Daily'd, then stored 2 yrs ago.
              • dnguyen1963
                • Nov 2011
                • 2651
                cut yourself thin rubber gasket that would fit behind the plate. Use two wall-anchoring screws (the one where the body would expand as you tighten the screws - find one with the correct diameter) to re-attach the plate onto the body. That should keep the water out until you find a permanent fix.
                • audiquattrot
                  • May 2008
                  • 3836
                  haha you got it man Thanks!
                  #snwmble
                  Current:
                  Past:
                  • audiquattrot
                    • May 2008
                    • 3836
                    sounds like a good remedy. I think the tricky part about that is keeping the water from coming in around the locking pin that shoots out when the doors lock. But def something i'm gonna try. Thanks!
                    #snwmble
                    Current:
                    Past:
                    • dr.strangelove
                      • Jan 2005
                      • 847
                      http://realoem.com/bmw/showparts.do?...82&hg=41&fg=50
                      numbers 23 and 12.
                      number 12 lists as a "Rubber Boot"...
                      perhaps what you're after
                      • audiquattrot
                        • May 2008
                        • 3836
                        numbers 23 and 12.
                        ahhhh yes thats it!! Question i wanna find out from anyone here....how is #12 held into the body? I'm wondering why it disappeared after the car was painted. There is a 1/4 inch gap if you look in the the hole (2 sets of holes)....i wonder how in the hell I would get #12 back into the body. Thanks for that diagram!
                        #snwmble
                        Current:
                        Past:
                        • dr.strangelove
                          • Jan 2005
                          • 847
                          I'm not by my car, but i do remember it being a combination of outside and inside work.
                          You will likely have to remove the inner trunk liner (passenger side, and very easy) to see what you're working with.
                          I can try to take a picture for you, but we all know how bad i am at getting pictures for people.
                          • bmwstephen
                            • 2463
                            that paint cut off line looks mighty fragile...
                            • audiquattrot
                              • May 2008
                              • 3836
                              That would be greatly appreciated! I peeled the pass side lining and couldn't see that far back . I'll try again when i get home from work.
                              lol it really isn't. It is the only FLAW on the entire repaint...and its actually really smooth, and appears to have been sanded and buffed out. Whatever imperfections you see when you open the gas tank door, was cleared over. The rest of the car is 1000% immaculate ;)
                              #snwmble
                              Current:
                              Past:
