running lean?
  • neogenetik
    • 38
    running lean?
    hey guys i have a 89 325iC...m20
    i hooked up my car to a sun emission tester
    and i got some results
    and my afr was at 16.8-17.1
    i was wondering if that was way to lean
    and is there a way to get it around 13s afr
    i heard theres a special tool you can adjust your a/f with
    my car doesnt run as good as it used to either
    i would go WOT and the rpms would go up but it doesnt have the same push it had
    i changed oil and plugs....
    anything else be the problem
    just needing your help thanks
    ej
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Injectors? Could go with some 17.5lb e30 M3 injectors and an AFPR though neither are required.
    Have you checked to see if your car is throwing any codes?
    • neogenetik
      • 38
      may have some codes
      not sure dont have a scan tool to find out
      • Rob
        • 8166
        is your motor stock?
        BEERTECH
        • neogenetik
          • 38
          yes stock motor
          w/ JC chip and b&b tri-flo
          • Rob
            • 8166
            put the stock chip in and try again.
            BEERTECH
            • demlotcrew
              • May 2004
              • 297
              Bigger injectors are not the way to solve this problem!
              You may have a air leak around the inlet manifold.
              Andrew
              Andrew AT E30zone.co.uk | H23-is | S14
              • Rob
                • 8166
                Andrew- are we seeing a pattern here? :p
                BEERTECH
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  Bet you it's the chip combined with the stock aging fuel system. It was in my case. Do what Rob said, put the stock chip and try again.
                  • demlotcrew
                    • May 2004
                    • 297
                    lol
                    • bddog
                      • 351
                      Make sure you have no intake leaks. The intake boot can hide a big leak.
                      Oxygen sensor. Needs replacing every fifty to seventy thousand miles, or as soon as it goes bad.This will throw your mixture off.
                      Temperature sensor. or wire. A bad one will make your ECU think your engine is cold. I always thought a 15 to 1 fuel mixture was optimum. Am I wrong?
                      • neogenetik
                        • 38
                        thanks guys
                        i will be doing that this weekend once i get the chip from my old house
                        • Digitalwave
                          is a poseur
                          • 6299
                          Stoich is 14.7:1, but that isn't really the optimal A:F ratio. It depends on the application, but you want more like 13-14:1.
                          RISING EDGE
