Early vs Late model chassis
  • bmwguy325is
    • May 2011
    • 1263
    The entire rear sheet metal of the car is different. Thus why the rear wheel arches are different. Plus the larger tail lights.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • CW325
      • Jul 2011
      • 1434
      early models have 2 front tow hooks and late models have one that threads in the bumper shock.
      • ApexGoblin
        • Jun 2011
        • 888
        dont the 83-85 318 have rear drum brakes and not disc
        apexgoblin - versteht nicht jeder. Ist auch besser so!
        • bmwguy325is
          • May 2011
          • 1263
          The early cars the tow eye screwed into the bumper. You had to remove the front plate.
          • TobyB
            • 5264
            hmmm, 2/86 eta has 2 loops welded to the chassis as tow hooks...
            but no, the shells are structurally identical. The rear quarters, tail panel and front
            rad stuff is cosmetically different.
            t
            • kman_e30
              • May 2007
              • 573
              all the early 318s have drums brakes in the rear as far as i know
              84 318i drift car
              04 mk4 gti 1.8t
              96 e320
              63 plymouth valiant
              • Jean
                • 18228
                Originally posted by Holland
                Doesn't the 83 318i have a completely different rear seat, and the chassis part that it bolts to higher? I thought I saw that on a thread here.
                the bottom part of the rear seat is different in how it mounts on the VERY EARLY e30s, 318 and 325...but aftr 85 it was the same as the rest.
                yes, but that's a simple trailing arm swap away.
                • Holland
                  • Nov 2008
                  • 7212
                  Early 325's also have the 48mm strut tubes.
                  Originally posted by DEV0 E30
