Cylinder Hone Size & Grit
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    About to deglaze the cylinders in a M54B30 (84mm bore).
    My understanding so far is that I need an 89mm Flex-Hone (ball hone) at 240 grit?
    Can anyone else confirm?
  • RobertK
    • Jun 2005
    • 5864
    Surely someone on here has had experience honeing a M20 or M50 block?
    • Bearmw
      • 1323
      Apparently you are a pioneer. I would like to know as well.
      • Hey_You
        • Nov 2009
        • 963
        I just used a hone on my cylinder walls, I don't have a super sweet 6-cylinder, but I used the kind with sanding stones. I used medium grit stones, turned out pretty good as I could adjust the tension on the stones and not take away too much material.
        85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
        • jrdeamicis
          • Nov 2008
          • 956
          I use a 320 ball hone on my stuff. Mine specified a size range.
          Past Car : E30 S50 6 Speed 5 Lug 3.73
          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
          ___________________________________________
          BNB Designs
          Engine Swaps, Fabrication, Innovation, General Repair
          Richmond CA
          Julian 848-248-8029
            Honing cylinders isn't something I would DIY. The block goes to a machine shop for cleaning and cross hatching honing. To do it right you need a machine that controls both rotational speed and rate of advance so as to wind up with uniform 60 deg cross hatch.
            • b*saint
              • 3794
              I agree. Are you sure the M5x doesnt have cylinder liners or plated cylinders?
              Ma che cazzo state dicendo? :|
              • RobertK
                • Jun 2005
                • 5864
                M54 has iron sleeves.
                Went with 89mm 240 grit Flex Hone. Appropriate for deglazing iron cylinder walls.
                This is not for a performance tear down and rebuild. Just simple piston ring and rod bearing replacement so everything I've found points to a 240 grit ball hone.
                • TobyB
                  • 5263
                  deglazing
                  Yup, that will work. Don't use synthetic oil for the first change or 2
                  t
                  • thebutterson
                    • 463
                    I disagree on the requirement for a machine. Metric Mechanic does all of their's by hand using the stones. They are really good at it, and the accuracy to which they can do it is amazing. I will tell you though that the ones they use are far more expensive and higher quality than the common one's I see sold everywhere.
                    • rjteeter
                      • 75
                      I'm curious how this turned out. I am in the same boat.
                      flickr
                      ifuckindrift
                      • RobertK
                        • Jun 2005
                        • 5864
                        I've used my Flex Hone 3 times so far and it worked great.
                        So far I've used it to rebuild a M54B30, M50 stroker, and just last week used it when rebuilding the S50 for my swap.
                        • rjteeter
                          • 75
                          Would you point me in the direction of which hone you bought and where you bought it from?
                          flickr
                          ifuckindrift
                          • RobertK
                            • Jun 2005
                            • 5864
                            http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
                            Its messy and whatever drill you use will get oily so I recommend buying a cheap $18 variable speed drill from Harbor Freight just for honeing. Mine is soaked in 20w-50
                            • rjteeter
                              • 75
                              Just placed my order. Thank you.
                              flickr
                              ifuckindrift
