Fixed my odometer. Now my temp gauge doesn't work.
  • Chubtone
    • Feb 2012
    • 66
    So I was mildly annoyed that my odometer and trip meter didn't work. I ordered the new gears from the guy on ebay and read through his directions and watched his how to video.
    It was a pain getting the gauge cluster out, but it will be much easier the second (last!) time. :)
    I ordered all new light bulbs for every position in the cluster, for this next time I pull it out, but does anyone know why as soon as I start the car, the temp gauge pegs all the way to the right/red and doesn't move at all. It's cool that my odometer works now, but that working temperature gauge was much more important.
    Any tips on what I might have done wrong or suggestions on what to do next time I pull it out, or for who I can send the whole cluster to for testing and repair?
    Thanks
  • Kershaw
    • 11822
    si board battery.
    AWD > RWD
      • 34844
      Originally posted by Kershaw
      si board battery.
      ...has nothing to do with the temp gauge.
      I believe it being pegged to the red means the connection could be open. Check the grounding nut on the back of the gauge. it's pretty simple - the gauge motor itself gets power, and there's a resistance curve input from an NTC sensor on the engine. that's it. no SI board batteries. :|
      for the gas gauge - same thing. check the nut on the back. it's the ground for the gauge itself.
      It's sort of a stupid design, and a common problem. On the E36, the gauges are exactly the same, except they fixed the ground nut issue and made it a pin inside the cluster instead.
        A bad SI board can kill the temperature gauge, but generally in that case the tachometer & econometer will also be inop.
        The gauge driving to the red means that the gauge is seeing a very low resistance or even a short. But a bad connection where the gauge mounts to the main PCB in the cluster can cause this also.
        • Chubtone
          • Feb 2012
          • 66
          Thanks guys! There's a few things for me to check.
          • Chubtone
            • Feb 2012
            • 66
            Just wasn't grounded correctly on the back of the gauge. It had the wrons size nut on it so I put the right size on and it is back to working fine. Thanks for the help.
