Urethane Bushings
  • aaron_silva
    • 1785
    Urethane Bushings
    The Ground Control RSM's use urethane bushings and I think they are the culprit for the annoying squeak-squeak I have. What type of grease/lube should be used on lease. White Lithium grease?
    TIA
  • Ryan Stewart
    I Love Miatas
    • 8978
    ive been told anti sieze compound. basically a copper grease.
    Im now E30less.
    • aaron_silva
      • 1785
      I bought lithium grease and anti siezing grease. Would puting either one of these make the problem worse? Is one better than the other because it will last longer?
      Thanks
      • Ryan Stewart
        I Love Miatas
        • 8978
        ive been repeatedly told anti-seize and have used it to no ill effect. I used Lithium grease at first but I think the stuff i had was too thin and only worked for a few weeks.
        Im now E30less.
        • aaron_silva
          • 1785
          Thank you very much :up:
          • MattM20
            • 641
            god i'm such a idiot! i just realized that's probably the source for my squeak, it started within a day of installing my billet RSMs, but i thought it was my sway bar or trailing arm bushings :evil: thank you for starting this thread :)
            • aaron_silva
              • 1785
              Bad news...my squeak is still there. Now I am thinking it has nothing to do with the suspension. Tomorrow I will investigate a possible SQUEAKY SEAT!! :evil: After 1 hr. of looking, greasing, and assembling, it is still there.
                • 34844
                all my suspension bushings are urethane and none of them squeak. :)
                • Paul Q
                  • Jan 2004
                  • 17
                  I had a similar problem when I first installed my GC rear shock mounts.
                  Is the nut at the top of th shock & shock mount assembly tight enough?
                  If it isn't it will cause a squeak.
                  Regards
                  Paul Q
                  89 325ic
                  [/img]
                  • aaron_silva
                    • 1785
                    Yeah the nut is plenty tight. I will look more into it tomorrow.
                    Thanks
