Windows and ac suddenly don't work
  • ezlnh8u
    • Feb 2012
    • 254
    Ho everyone, I put the top down on my 90 e30 and I tried putting the windows down, and got nothing, I noticed the ac didn't work as well, I was trying to change the from bezel computer to anther one, but I couldn't get the 2 bottom screams off, so I kind of gave up on that, any suggestions? Many thanks.
  • Northern
    I like cupcakes & sh!tboxes
    • 5192
    check your fuses.
    Originally posted by priapism
    Originally posted by shameson
    • ezlnh8u
      • Feb 2012
      • 254
      Checked the ones under the hood, they are all good, is there any others? Would me messing with center console control affect it?
      • irish44j
        • 2763
        manual crank.....the're the only e30 windows that never break :)
        what about the circuit breaker button on the dash? Or is that just on early models?
        Stage rally/rallycross e30 build/competition journal
        Track/street e21 build
        visit Condor Speed Shop
        visit Motorsport Hardware
        [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
        • ezlnh8u
          • Feb 2012
          • 254
          But it's not just the windows, the ac and heater does not turn on
          Anymore as well, I was trying to change
          The center console, but didn't pull it out, I couldn't get the bottom screws out, so I left it alone, after that the probblem started.
          • irish44j
            • 2763
            well, the window wiring harnesses all go under the center console near the shifter, so maybe you pulled them loose off the switches? IDK why that would have affected the heater or AC.
            Isn't it 75 and sunny every day in Pasadena anyhow? You don't need no stinkin AC or heat!
            IDK what else to say - check all fuses - check your Bentley to see what fuses are used by both the HVAC and windows (if any) and check those first. Otherwise, you will need to pull the center HVAC console and stuff in that area and find whatever wire has come unattached....
            • ezlnh8u
              • Feb 2012
              • 254
              Yes it's sunny here, but I still like to still want the
              Option to us me
              Heater in the morning, I leave at 5am, and it's pretty cold sometimes, I recheck everything tomorrow, keep the
              Suggestions coming, I will update on the
              Findingstomorrow.
              • drez14
                • Jun 2011
                • 211
                When you say heater and AC do not work, do you mean the blower motor?
                There is a wire that goes to the starter so that when you are cranking to start, it cuts power to the windows and blower. I would check the relay or parts associated with that. maybe you accidentally shorted something and the relay went.
                When i was doing my swap, i screwed up my harness because my blower and windows didnt work.. turns out that i did not connect my starter correctly.
                I know this has nothing to do with removing the center bezel, but its a possibility.
                • tttoon
                  • 275
                  unloader relay.
                  • ezlnh8u
                    • Feb 2012
                    • 254
                    loader reduction relay? is that the same?
                    • ezlnh8u
                      • Feb 2012
                      • 254
                      yes the blower motor, and i did have my starter switched out yesterday, but if iam correct, the windows did go down right after i picked it up from the shop.
                      • ezlnh8u
                        • Feb 2012
                        • 254
                        ok, i took out fuse 10, and everything worked, not sure why that fuse is causing the issues? fuse looks fine.
                        • ezlnh8u
                          • Feb 2012
                          • 254
                          update, so now that i took out fuse 10, i noticed that my temp sensor is acting up now, and the little meeter in the middle of the cluster goes green then yellow, then it stops, the cluster is acting up now, is this because i took out fuse 10?
                          • tttoon
                            • 275
                            Yes, it's the same as the load reduction relays (K5 and K7 I think). Basically, you should disable this function or buy a new starter. Most people just disable it and don't crank the blower up and lower the windows when starting. I believe you'll have to take the 30h wire of the starter (thin wire, check an ETM for color) and ground it. There are DIYs on this site.
                            • ezlnh8u
                              • Feb 2012
                              • 254
                              the shop did install a new starter, its in now, he car starts right up but, the cluster issue continues.
