What's the electrical signal on the VSS wire?
  • TobyB
    • 5280
    So I was thinking about logging channels, and realized that logging rear wheel
    speed's as easy as capturing the VSS sensor... if I knew what, exactly,
    what that signal was!
    Is it anything more complicated than a tach signal from the rear end sensor?
    (which is, what, 8 blades or so, so 8 pulses per wheel rev?)
    Thanks!
    Toby
    • 34844
    it's a 9-tooth wheel. get the signal from the back of the cluster (where the cruise control plugs in), not straight off the VSS sensor. the sensor itself doesn't output a good enough signal to be useful.
    a 0-5v switched input should work. you could also tap into the black/white wire of the C101.
    • TobyB
      • 5280
      Righty- o, so VSS (the signal from the cluster)'s just a conditioned 9 pulse- per- rev signal?
      Sounds pretty straightforward.
      Thanks!
      t
        • 34844
        yep! all you need to know is the size of your tire and you can calculate the pulses per mile/km.
