m20 3.0
  • Digitalwave
    is a poseur
    • 6293
    #31
    Originally posted by SickE30
    wow, dave's car only put down 180 to the wheels..that's pretty much a bone stock M50 if I am not mistaken. With tuning that car could've been sick. Well, sicker.
    Nah, bone stock M50's are like 189 crank...
    RISING EDGE
    • SlammedE30
      • 741
      #32
      That would be a 2.8, 2.5's are 170.
      -Ted
      • decay
        • 5637
        #33
        Originally posted by darien28
        you think the smog shop will notice my snail-shell next to the exhaust after I build my engine up??
        HAHA. in irvine? you bet your a** they will. :P
        listen for something non-honda (they have CARB-legal kits) with a blow-off valve, and ask the driver where he gets smogged- a 6-pack in the passenger seat may help "slide" you through the visual part of the test- but MAKE SURE you run lean enough at a steady 3500rpm so you pass sniffer- in this state, the results of any smog test, pass or fail, are automatically transmitted to the DMV.
        past:
        1989 325is (learner shitbox)
        1986 325e (turbo dorito)
        1991 318ic (5-lug ITB)
        1985 323i baur
        current:
        • Mystikal
          Wheel Fitment Expert
          • 9602
          #34
          -Ted
          M50's are 189 crank. M52's are 190 crank. :idea:
          • Digitalwave
            is a poseur
            • 6293
            #35
            -Ted
            M20's have 168, M50's have 189 and M52's have like 190...
            RISING EDGE
            • M-technik-3
              • 18946
              #36
              This is funny Tuners like Alpina and Hartge were putting numbers or over 205 with engines displacing 2.7 liters. It can be done, but if you buy all new parts to make a brand new engine yes it's going to be quite expensive.
              Refreshing an M50 and slipping one into an E30 not expensive but the time involved with conversion is $$.
              Cost to value ratio, well how long do you plan on keeping the car? So many variables, I think the M50 route is worth the money. But That's just my $.02
              • Rob
                • 8166
                #37
                Wheel or crank?
                BEERTECH
                • M-technik-3
                  • 18946
                  #38
                  Unsure but They built some stout engines in many varieties. Having both good low end and top end. There have been many stout engines built, we just want to have a nice quick answer for our lack of power.
                  Quickest answer would be FI. Far cheaper than an engine swap.
                  • Rob
                    • 8166
                    #39
                    all the built m20s i've driven were just like that, stout low end with a great pull up top. Unfortunately people are getting too caught up in peak numbers, which are all but useless...
                    BEERTECH
