What kind of BBS' are those? I didn't know BBS did multi drill.
Assistance Please!! BBS New Wheels
4x100mm, center hub is 57mm, wheel bore 57.1mm
6" rim width: 33mm offset = 4.7" backspace
6" rim width: 35mm offset = 4.6" backspace **
6½" rim width: 26mm offset = 4.7" backspace
6½" rim width: 30mm offset = 5.0" backspace **
7" rim width: 20mm offset = 4.7" backspace
7" rim width: 25mm offset = 4.9" backspace **
7½" rim width: 20mm offset = 4.9" backspace
** Factory sizes for an E30
Wheel diameter is irrelevant concerning offset. This is the Specs for the E30.
The Gold wheels are 16x7. So would this Calculate meaning I need a 32mm Spacer??Comment
OK - hub rings cannot fill a negative space. You said the wheels have a 56.1 bore and as you also noted the E30 has a 57.1 hub. Think about it - a 57.1 mm dowel into a 56.1 mm hole - don't work. If you have a large offset, which you've never stated what your wheels have, you might be able to find (or get some made) spacers that compensates for this.Comment
Maybe I'm wrong but if they were 56.1 they wouldn't be on his car in first place cuz they wouldn't fit right? I mean im just guessing here. Not a rocket scientist or anything..OK - hub rings cannot fill a negative space. You said the wheels have a 56.1 bore and as you also noted the E30 has a 57.1 hub. Think about it - a 57.1 mm dowel into a 56.1 mm hole - don't work. If you have a large offset, which you've never stated what your wheels have, you might be able to find (or get some made) spacers that compensates for this.
If you center bore on the wheel is larger than your hub you need hubcentric rings. I highly doubt that is the issue. I've ran e39 wheels on an e34 without the rings and only had vibration. No "clunking"
If your getting clunking then something is worn out. Strut bearing or control arm bushing would be my guess. Would guess that jacking up the car and changing the wheels was the "straw that broke the camels back"Comment
He definitely needs hub rings you can tell by the pic.OK - hub rings cannot fill a negative space. You said the wheels have a 56.1 bore and as you also noted the E30 has a 57.1 hub. Think about it - a 57.1 mm dowel into a 56.1 mm hole - don't work. If you have a large offset, which you've never stated what your wheels have, you might be able to find (or get some made) spacers that compensates for this.
And welcome, nice to see someone else in Chicago.I want a nice set of smoked MHW's (I know, get it line)
Can't tell from the pic. He has shown no pics of the back of the wheels. A lot of wheels have the through holes larger than the hub locating surface in the rear. They need to be removed and measured.Comment
