clicking noise driving me crazy!!! Help!
  • evil-diesel
    • Jul 2011
    • 199
    I have a weird noise coming from somewhere under the dash on the drivers side. It a constant ticking noise that will start at about 2500rpm and increase in frequency all the way up to the red line.
    I already took out the gauge cluster thinking that it might be one of the gears of the odometer or rev gauge, but i found nothing wrong with those.
    the noise seems to be linked directly to the revs, but it doesn't sound like it's coming directly from the engine.
    can anyone help? i would appreciate it...
    -chris
    Early 323i
    http://www.r3vlimited.com/board/showthread.php?t=214425
    320i V8 Swap
    http://www.r3vlimited.com/board/showthread.php?t=345807
    M3
    http://www.r3vlimited.com/board/showthread.php?t=310470
  • IRON-E
    • 16548
    Blower motor is out?
    @IRON-E30 aka Edwin:D
    • Threehz
      • 1480
      Maybe your speedo cable is wearing out or has an issue and is catching on something?
      Different strokes for different folks.
      • Mr. Tasty
        • Jul 2011
        • 3421
        my odo gears click?
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • dogsbark26
          • Nov 2008
          • 533
          Is ticking electrical or mechanical? There are very few mechanical things inside the passenger cabin under the dash on the drivers side.
          • immajackuup
            • Dec 2010
            • 1132
            relay acting retarded?
            • valleymotorwerks
              • Jul 2005
              • 174
              speedo cable? really?
              Something could be contacting the steering shaft and it's being transmitted up into the car... I assume you drove the car with the dash out and the sound is present? Will it make the noise with the engine revving and the car out of gear? If so remove the lower panel under the steering column and start touching relays. OR you can use a stethescope to pinpoint the sound.
              Valley Motorwerks
              1988 E30M3
              • b*saint
                • 3794
                Here's going on on a limb, would a ground arc produce that sound?
                Ma che cazzo state dicendo? :|
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  No.
                  • long tall eta
                    • Jul 2010
                    • 1536
                    every now and again i get a clicking that seems to be coming from under the dash or from under the hood close to the fire wall on the drivers side. it is not how ever rpm related. come to find out that it's the cruise control cable/modual. only hapens 2 or 3 times a year but the last time it even did it with the cars ignition on but not running. i poped the hood and when i tugged on the cruise cable the sound changed and it's definitly cable related and in the modual. could this be your problem?
                    • TobyB
                      • 5263
                      No, it's your tach cable, probably where it comes out of the distributor. Sometimes
                      that right- angle drive gearbox wears and lets it wobble all over...
                      hee
                      (yes, that answer DOES work for some cars, you know)
                      How about something (fuel line, etc) touching the firewall and transmitting noise back?
                      The steering column's a good thought...
                      t
                      • evil-diesel
                        • Jul 2011
                        • 199
                        thanks for all the help guys....:D
                        turns out the problem is the clutch. i figured this out by driving the car and slightly engaging the clutch when the noise appears. as soon as the clutch is engaged the noise goes away.
                        i'm installing a full sachs clutch kit next weekend and i hope that will take care of the noise.
                        -chris
                        Early 323i
                        320i V8 Swap
                        M3
                        • bmwstudent
                          • Sep 2011
                          • 1364
                          don't forget your throwout bearing, that's probably whats making the noise. R&R pilot bearing too. One piece a lot of people forget to do is the clutch arm pivot/anchor pin inside the bell housing. It can be purchased from dealer for a couple bucks and they do wear down over time. They simply push in for installation.
                          • long tall eta
                            • Jul 2010
                            • 1536
                            so, with the clutch ped. out, there's no noise? or with peddle depressed, no noise cause as soon as i touch my ped. the sound stops. kind of like it's the cruise switch that turns it off when you hit the clutch or brakes.
                            • dnguyen1963
                              • Nov 2011
                              • 2649
                              Check your cruise control module. It has been known to make clicking noise. Depressing the clutch disengages the cruise control, thus, stops the clicking noise.
