Silicone ? REALLY !
  • ruqknuf
    • Jul 2009
    • 378
    Silicone ? REALLY !
    Removing the covers on the rear taillights to change a bulb - happen to notice that the PO used some clear silicone to secure the tailights to the car. WTF ? ! Ideas on removal ? ? - (other than a hammer and chisel :?)
    Leave Feedback here:
    http://www.r3vlimited.com/board/showthread.php?t=261541
  • BAVARIAN IRON
    • 979
    heat gun
    • jeffnhiscars
      • Jun 2011
      • 6011
      Silicone should just peel off, sometimes with a bit of coaxing. If it wont then its something more obnoxious.
      Alice the Time Capsule
      • ruqknuf
        • Jul 2009
        • 378
        Originally posted by BAVARIAN IRON
        heat gun
        Cool, I'll give it a try. Still trying to figure out why ?
          The silicone is probably there to fix a leak. It could be that the gasket just needs to be replaced, or there could be previous damage that causes the gasket not to seal.
          • tonerrrr
            • Jul 2011
            • 935
            I have the same exact problem thanks to my PO. No peeling it off easy either, I'll have to try the heat gun trick.:hitler:
            instagram: @tonerrrr
            High resolution E30 Fuse Box 300dpi PNG
            • jeffnhiscars
              • Jun 2011
              • 6011
              Silicone stays soft and pliable and is also quite flammable. If it won't peel its probably something else. Id be REAL careful using a heat gun around paint.
              • SteveJ
                • Feb 2012
                • 98
                What I recall from my micro/miniature repair schooling in the Navy,
                Silicone- cut and peel
                Epoxy- sand/file
                Urethane- solvents
                Using heat will just make the adhesive more pliable. Cold would probably help more to remove silicone. Get some plastic scrapers.
                A little heat does help in removing bumper stickers and tape, but once the tape/sticker is off a solvent will most likely be needed to remove residual adhesive on the surface.
                Silicone should not be flammable after it has fully cured. The chemicals in it that allow it to flow are flammable.
                • StereoInstaller1
                  GAS
                  • 22679
                  WD 40 works to get silicone off
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • MJCRO
                    • Apr 2012
                    • 597
                    Heat gun FTW.
                    • Blackout
                      • Apr 2011
                      • 4130
                      Industrial blow torch.
                      » PARTS FOR SALE
                      » TRANSACTION FEEDBACK
                      • immajackuup
                        • Dec 2010
                        • 1132
                        weak^^,flame thrower works best.
