Fuse question
  • ezlnh8u
    • Feb 2012
    • 254
    Fuse question
    Would putting a 35amp fuse were a 7.5 one goes affect it in any way? i put a 35 for fuse 10 wich uses a 7.5, the car has not given me any warning signs, but i was wondering in the long run will it give me issues? 90 e30
  • StereoInstaller1
    GAS
    • 22679
    Warning, no. Fire hazard, yes, possibly.
    Good luck.
    Closing SOON!
    Thanks for 10 years of fun!
    • 89 e30
      • 249
      Just buy the right fuse and you don't have to worry about anything. It's not like they cost a lot
      BIMMER für IMMER
      • AndrewBird
        The Mad Scientist
        • 11898
        By putting a higher amperage fuse in, you basically make the wiring in the car the fuse. Whatever will take the least amperage will melt. In a normal case, it is the fuse. This protects the wiring from melting if something shorts out. In your case, the fuse is a much higher rating then the wiring, so if something goes wrong, your wiring is going to melt and possible cause a fire.
        In short, DO NOT use a higher amperage fuse in place of a lower amperage one.
        • StereoInstaller1
          GAS
          • 22679
          OK, so lets say you swap out car stereos, and the new one pops the 7.5A and has a 10A fuse on the power lead...that would be fine to swap in a 10A, but still not a 30A.
          Pay attention to the loads and fuse accordingly. Don't overstress the wire, you can't triple the amperage on the same wire.
          Closing SOON!
            • 37833
            I replaced my fuses with paperclips.
            Grover Beach, California
            BimmerHeads.com
            • hamilton325i
              • Sep 2011
              • 83
              Jumpers FTW!
              Do you lick your fingers and grab on to make sure you've got a good ground? :D
              • German Audio Specialties
                • Feb 2012
                • 374
                I heard you stuck a pair of needlenose pliers in the fuse socket and duct taped it in place...
                August R3VLimited Special: E3012 "V3" box: $225 shipped
                Tutorials: Killer $500 Stereo | E30 Vert Dual 8'' Box Installation | E3010 Amp Rack Installation | Radio Wiring and Amp Bypass
                • ezlnh8u
                  • Feb 2012
                  • 254
                  Thanks I will change it back, I notice my auto shop only carries 15 and up, I have not seen a 7.5 any suggestions?
                  • TobyB
                    • 5280
                    find another shop.
                    t
                    • StereoInstaller1
                      GAS
                      • 22679
                      Go find a junkyard with a BMW in it, grab a handfull, should only be $5 or so
                      Closing SOON!
