Fuck Starters.
  • Bimmerfanatik
    • May 2004
    • 5349
    #31
    Originally posted by Brew
    We sometimes use a wrench like this:
    But most of the time if you use a big 1/2" impact you can spin the bolts out in one shot without even using a wrench. You guys need some fucking air tools. And a lift.
    Some day :) You're right, the air gun would probably make things easier (along with every other job. gr. garage doesn't have enough power to run a compressor.)
    And yes, I am soliciting gay sex to Dan in return for his assistance in finishing Dave's car. :)
    • Digitalwave
      is a poseur
      • 6299
      #32
      oDANG SON
      RISING EDGE
      • Bimmerfanatik
        • May 2004
        • 5349
        #33
        oDANG SON
        No need to worry - he must have had prior engagements, as he isn't at the garage tonight.
        His loss.
        • DanGillan
          • Mar 2004
          • 4061
          #34
          yes. i was hanging out with a girl instead of sweaty dudes in a gross garage. my b. thanks for the offer though.
          Dan
          • turnofftheradio
            • Apr 2005
            • 448
            #35
            :p I have a compressor and power in the shed, but no garage. 2 bad situations. trade you a compressor for a garage? how do you part cars without a compressor? I am amaised! and impressed.
            • Bimmerfanatik
              • May 2004
              • 5349
              #36
              Hand tools and long breakers are your friends ;)
              It's a challenge, for sure. We're working on it. Where were you this weekend?
              Dan, you probably just would have slowed us down - thanks for finding something else to do ;)
              • Dave
                E30 RAT
                • 11675
                #37
                What, no new sig picture yet????
                Current Cars
                2014 M235i
                2009 R56 Cooper S
                1998 M3
                1997 M3
                • Bimmerfanatik
                  • May 2004
                  • 5349
                  #38
                  Double check - where's YOURS? :)
                  • wastedincome
                    • Aug 2004
                    • 906
                    #39
                    [QUOTE=Bimmerfanatik]Some day :) You're right, the air gun would probably make things easier (along with every other job. gr. garage doesn't have enough power to run a compressor.)
                    QUOTE]
                    Yeah Speaking of "power" the nite Jarvis and I were there the guy in the house was rambaling on bout using too much and tripping breaker's....
                    I hadda laugh, we had 2 lites on......
                    Wastedincome420@yahoo.com
                    CURRENT STOCK LIST:
                    00' e38 750iL HighLine=Highway Queen
                    92' e30 318 vert=Aint going anywhere
                    91' e34 535iM=Aint going anywhere
                    91' e34 525iA=For parts
                    92' e34 535iA=For parts
                    • Bimmerfanatik
                      • May 2004
                      • 5349
                      #40
                      [QUOTE=wastedincome]
                      QUOTE]
                      What guy? lol - fuck them, the few times I've blown it was when I used the shop vac AND had the lights on - heaven forbid.
                      You gotta come check out the cab this week man.
                      • bmwsmurf
                        • 509
                        #41
                        It took me about two hours to do this. Would have been faster, except the nut on the top bolt was slightly messed up and I couldn't get the wrench on it properly.. and didn't realize that was the problem until everything was off.
                        Top side: standard 17mm wrench.. you can slide it right in to the hold the nut from spinning. Then, with a flex ratchet head (and maybe a U extension), you can get the bolt off. Not too bad. Straight ratchets won't work.
                        Bottom side: Thought this would be easier, but it's actually also a pita. Luckily, I have an extremely short stubby flex head that I could force in there to hold the nut and used a wrench on the bolt.
                        Yes.. I replaced it with a fully reman unit from bavauto.. About the only new part on the car :D. I have a working used unit somewhere as backup just in case.
                        Visit the 3 series heritage site (work in progress):
                        http://www.creativesmurf.com
                        • Bimmerfanatik
                          • May 2004
                          • 5349
                          #42
                          The newer cars have an e-bolt head on the tranny side (reverse torx) so your method above will only work on early cars (like my euro, I did the same thing.) What would work best is a 12 point 10mm wrench - only it'd have to be at least a foot long to get in there. I'm going to look for one so this job doesn't kick my ass EVER AGAIN. :)
                          • bmwsmurf
                            • 509
                            #43
                            The BMW ETK lists hex bolts even for later cars, but who knows. At least it's not as bad as the E36, which from what I hear is even a bigger PITA.
                            • mspiegle
                              • 1026
                              #44
                              I just put the AT from the '90 into my '87 last night... you better believe I did the starter at that time too.... no way in hell do I want to go through what you went through anytime soon.
                              Michael Spiegle
                              '01 Ford Escape / Daily Driver
                              '99 M3 / Track Car
                              '87 325is bronzit / wtf car
                              '06 Daytona Triumph 675 / Daily Rider
                              • Dave
                                E30 RAT
                                • 11675
                                #45
                                So you put that same bitch of a bolt back in there? How new is that starter anyway???
                                :D :D :D :D :D
                                Current Cars
                                2014 M235i
                                2009 R56 Cooper S
                                1998 M3
                                1997 M3
