more air w/o forced induction
  • BavBeater85
    • Mar 2012
    • 143
    Anyone have suggestions on how to get more air into an m20b25 w/o boosting...Im running rich and figure if i can just increase airflow i wouldnt have to revert back to stock fuel setup
    may you rest in peace, or pieces, whichever comes first
  • b*saint
    • 3794
    I have this idea if you introduce more air in front of the sensor, you will run just as rich, this time you will be wasting more fuel. You have to add more air behind the metering sensor to lean it out, which you can't really do.
    The way you used to lean it out and get more power was smaller jets. But since we have F/I cars you have to change fuel mapping in my opinion.
    Ma che cazzo state dicendo? :|
      To get more air through the engine you must relieve the restriction on mass flow. Which means modifying the head and intake manifold or going to forced injection. Fiddling with the throttle body on intake is not going to help.
      You don't say what you've done to the fuel system, but if you installed larger injectors and did not install a chip tuned for those the engine will probably be running rich. The fix for that is to install a properly tuned chip, not to try for more air.
      • th3blue
        • 114
        leaf blower plugged into your house. the only downside is you need an extension cord as long as the distance you plan to drive your car.
        or you can remove fuel to get the correct ratio.
        1997 BMW 328ic 5spd sport Moreagrun Metallic
        1989 BMW 325is 5spd with a M50 swap
        2006 Audi A3 6spd DSG sport with APR stg 2
        • BavBeater85
          • Mar 2012
          • 143
          well, Ive got bosch 19# injectors, deatschwerks 255 fp and stock regulator...all tuned bya Mark D chip...the chip was ordered tuned for this setup and for 93 octane with 7100 rpm rev limit....Im confused because if the chip is tuned for more fuel, than I shouldnt be running rich, right?
          • BavBeater85
            • Mar 2012
            • 143
            also the spark plugs are showing that goopy dark stuff, which i believe is a sign of the timing being advanced too far
              • 34844
              Fix your o2 sensor?
              • Joe G
                • 2942
                Remove your hood.
                Current Car: 2011 BMW 135i, M-Sport, 6 speed
                Originally posted by lambo
                Sounds like you need a massage.
                Originally posted by kpeng
                Who the hell is Vlad?
                • BavBeater85
                  • Mar 2012
                  • 143
                  lol...I used to tell new guys at my diesel shop to take the back door off
                  • BavBeater85
                    • Mar 2012
                    • 143
                    Damn, just remembered I left the thermostat out....might just be runnin to rich cuz of that
                    • b*saint
                      • 3794
                      Well the engine would never know its warmed up so it would be in open loop constantly.
                      • PeaveyBassist
                        • Sep 2004
                        • 3511
                        ding ding ding
                        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                        Welcome e30 (brilliantrot '90 325is) 12/23/06
                        DaveCN = Old Man
                        My signature picture was taken by ME! Not by anyone else!
                        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                          • 34844
                          it's more that the engine will never warm up, so it'll be stuck in warmup mode which makes it run richer.
                          • bmwguy325is
                            • May 2011
                            • 1263
                            So really you need a block heater to augment those 19# INJECTORS.
                            Oh and remover hood as noted above.
                            Oh and when you do make sure you take of the lower portion on the intake box. Then twist the AFM and air box top 90 degrees so it catches on coming air.
                            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                            • b*saint
                              • 3794
                              yea open loop is warmup mode. I meant to say the ecu wouldn't know the engine is warmed up.
