fuel check valve?
  • BavBeater85
    • Mar 2012
    • 143
    fuel check valve?
    I recently deleted my inline fuel pump on my early model e30 and replaced the in tank pump with deatschwerks 255...well I seem to have inadvertently deleted this check valve? what affect would that have on the fuel system?
    may you rest in peace, or pieces, whichever comes first
  • TobyB
    • 5296
    Probably nothing with an in- tank pump...
    t
      • 34844
      it's built into the in-tank pump.
      you will have harder starts, mostly.
      • BavBeater85
        • Mar 2012
        • 143
        wild, because I do have hard starts when cold sometimes
          If the pump is working properly the fuel rail will reach normal pressure within a few turns of engine even if the rail starts with no pressure. A weak pump (probably not applicable here), an obstruction in the fuel lines, or a bad FPR could result in a delay in getting normal rail pressure. A rail fuel pressure will tell how quickly rail pressure comes up.
          Most commonly hard starts are from intake leaks.
