Car won't start again
  • evo30
    • Aug 2007
    • 19
    I busted my oil pan and changed it. i drove the car to get pressure washed to remove the oil from the bottom of the car. The car drove good for a while then it just shut off on me and won't start back up could it be my Fuel pump or did i mess something up by getting the bottom of the engine cleaned. Any info will be appreciated thank you ...
    You could have damaged the timing sensors with the pressure washer.
    • evo30
      • Aug 2007
      • 19
      thank you that could be the reason i was hearing a little tapping around the intake manifold i thought it was my lifters. can i change that sensor or is my motor finished @jlevie
        You can change the sensor(s). Where they are and home many depends on which E30 you have.
        • 36brua
          • 689
          there also may be accumulated moisture/corrosion in the C191 (fuel injection) connector located on the side of the engine under the throttle body. separate it and have a look
          My CA legal M60 swap
          The happening in our garage
          • evo30
            • Aug 2007
            • 19
            i have a 91 325i im going to check those out i thought it was my fuel pump..
            • Gregs///M
              • Mar 2012
              • 2459
              Most likely engine to chassis ground cable which connects oil pan to frame rail on drivers side. Without a good connection, starter won't turn or will work intermittently.
              Owner - Bavarian Restoration
              BMW and European Electronics Repair and Restoration
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
              Follow our Instagram!
