Resistor board for HVAC blower
  • Cyrix2k
    • 593
    Does anyone know of a chain store that carries one? My thermo switch is fubar and I'm dropping the m50 back in tomorrow... it's a whole lot easier to fix with the engine out!
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
    • 34844
    napa?
    • Cyrix2k
      • 593
      Thanks for the suggestion. It's not in stock locally for me but they do actually carry them. $53.29 for the part... I think I'll be going without a low fan for a while. The blower motor is questionable too so I should probably replace everything in the future.
      1997 540i/6 - stock
      • reelizmpro
        • 9556
        You mean resister coil pack?
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • Cyrix2k
          • 593
          this thing
          1997 540i/6 - stock
          • reelizmpro
            • 9556
            Take yours out and resurface the contacts with a scotchbrite pad.
            88 M3 - LACHSSILBER
            • Cyrix2k
              • 593
              I did. I started with contact cleaner and eventually would up using fine sandpaper. That temp sensor in the center refused to clean up until I basically mangled it enough that it no longer works correctly. Too late now though, the motors back in the car. Heat isn't a *huge* concern and the high speed fan works for now.
              1997 540i/6 - stock
