Icv?
  • aaron_silva
    • 1785
    Icv?
    I have had a surging idle for quite some time now. Every time I come up to a stop sign or sit in traffic, it goes from 500 to 950 rpms at a constant rate. Today when I got home from driving I popped the hood and unplugged the ICV and the idle was a bit high but didnt surge anymore. Is this a good sign that it is time for it to be replaced? I tried testing it but it is in the most inconvienent place (sandwiched between the intake mani and the firewall) and I dont know if I was getting accurate readings.
    I would like to know that is what is causing this idle problem before I go pick up a new one.
    I did recently replace: intake manifold gasket, most all vaccum lines, FPR, Fuel Pump and the TPS has the correct resistance for idle and WOT.
    Thanks in advance.
    Aaron
    • 34847
    try spraying the valve with some brake cleaner and see if that helps.
    • AdamF 88iS
      • 2051
      Ditto. Give it a good cleaning.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • aaron_silva
        • 1785
        I will try that again. I have sprayed it a few times in the past and it doesnt seem to do much. If that still doesnt solve the issue, is it a good possibility it is the ICV. It doesnt cost "that" much, so I might just pick one up.
        Thanks
        Aaron
        • AdamF 88iS
          • 2051
          Thanks
          Aaron
          318s have a lot of vacuum leak potential too. I'd check that as well.
          Adam Fogg- '88 M3
          • aaron_silva
            • 1785
            While I had the ICV out of the car I tested the resistance across the terminals and got a reading of 8.2 ohms. Does that mean anything to anybody?
            Also, does the little valve inside th ICV turn freely? I stuck a small pick and put a little pressure on it and it did not budge.
            Thanks
            Aaron
            • aaron_silva
              • 1785
              That piece inside doesnt move. Is it supposed be like that.
              Aaron
              • A_325i
                • Jun 2005
                • 680
                ummm i beleive its supposed to move?..everytime ive cleaned mine ive been able to move it freely?
                • aaron_silva
                  • 1785
                  Update for future reference:
                  After spraying the ICV, the idle seems to be a bit more normal. I still have a temporary drop in idle speed when the car comes to a stop, but it immediately returns to normal.
                  Thanks
                  Aaron
