Rollbar installation in 325i vert
  • BeamerE30
    • May 2012
    • 3
    As i havent heard much about such a modification, i was wondering if anybody knew about the procedure for getting a roll bar installed in an E30 vert.
    Where would i have to go to get this done?
  • ezlnh8u
    • Feb 2012
    • 254
    Good question, as i myself am looking for something like this.
    • RobertC
      • Dec 2010
      • 127
      A roll bar in a vert would be a great solution to taking the inherent flex out of the frame.
      My fabricator could do the job for you guys. Fully tig welded, excellent quality.
      ezlnh8u, your close enough to have this done locally in SoCal. If a roll bar can be built for your vert then it could then be a template for others wanting the same solution.
      Contact John Hickerson at fabrication@e30motorwerks.com
      You can also view www.hikfabrication.com
      Robert
      www.facebook.com/E30motorwerks
      • TobyB
        • 5263
        Roll bars don't take the flex out of much, really, except the roof if you happen to try to
        use it as the floor. Which, in a convertible, would probably knock your hat off...
        t
        • RobertC
          • Dec 2010
          • 127
          Originally posted by TobyB
          Roll bars don't take the flex out of much.
          t
          True, my thought was not just a roll bar only but have down bars to the forward section, basically a 4 point cage/street roll bar setup, or 6 point if you took down bars to the back, but this would interfere with rear seating.
          Street cars and roll bars/cages are always a compromise.
          • idanity
            • Jun 2006
            • 775
            i don't know if a 6 point is reasonable with the roof compartment....
            i pondered this, and even designed a harness bar, but eventually went with buying a $600 sedan to track. that has a much stiffer setup, and lighter too... imho, cabrios should not get cages unless they're the s2000's or miatas..if it comes in a sedan, get one.
            again, just sayin...if you do it, i am still interested in how it comes out...i have seen a few cabrios out there with cages, (actually only online), and always interested in how they come out.
            3 pedal club
            200,k+ club
            cabrio club
            port-matched- polished- purring www.BMWpark.org
            </div>
            linux since 1999
            • DaveSmed
              • Apr 2007
              • 1407
              Have you guys seen pics of four seater convertible anything with roll bars before?
              They look terrible! Go with a fixed roof for motorsports stuff, or a two seat vert.
              No one should want to drive a picnic basket around.
              -Dave
              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
              Need some help figuring out the ETM?
              • TobyB
                • 5263
                Somehow, that should have been used in one of the Jurassic Park movies...
                t
                • ezlnh8u
                  • Feb 2012
                  • 254
                  I emailed john, il update you guys with the findings.
                  • ezlnh8u
                    • Feb 2012
                    • 254
                    No email back from john.
                    • dnguyen1963
                      • Nov 2011
                      • 2649
                      QFT. If you are going to drive a vert you should know its limitations.
                      • bmwguy325is
                        • May 2011
                        • 1263
                        A full cage on the street is a bad idea anyways.
                        In a race you have helmet to protect your head but ya.....
                        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                        • JGee
                          • Jul 2011
                          • 264
                          Not True.
                          I emailed you on Monday and again yesterday on your (gum) yahoo account.
                          Maybe on your other email ;)
                          Basically roll bars start at $270
                          We need to talk about the details of what you want.
                          I just did a bar for a guy on here. That bar came out to just over $400.
                          The rear down bars or plates are not pictured but I also did the rear shock tower braces and cross-member.
                          Check it out.
                          John Hickerson
                          HIK Fabrication
                          HIK Fab
                          • JGee
                            • Jul 2011
                            • 264
                            No contact from ezinh8u.
                            HIK Fab
